Zeroing steering wheel?
Old 04-10-2006, 09:31 AM
plow's Avatar
How do you zero the steering wheel on a 97?
Old 04-10-2006, 12:39 PM
MDMIKE's Avatar
Theres an adjustment collar on the drag link (from the pitman arm on the steering box to the passenger side steering knuckle). Loosten both bolts, spray the crap out of it with some PB blaster or other lubricant, then, if it doesn't turn by hand, grab ahold of it with a pipe wrench and start turning while someone else watches the steering wheel (your key should be in the on position). Just turn the collar until the steering wheel is straight with the wheels again. HTH
MIke
Old 04-10-2006, 12:51 PM
berner's Avatar
I remember reading a thread years ago about how to do this. Make sure your tire pressures are even and you don't have a dragging brake. Find a level piece of pavement, drive the truck straight and mark the top of the steering wheel. Park it wherever you're going to work on it with the mark at top and adjust the drag link until the wheel is centered.
Old 04-10-2006, 07:43 PM
plow's Avatar
Thanks guys, I appreciate your help.
Mountaineer
18
09-01-2012 10:51 AM
98silver12v
06-01-2010 11:44 AM
LanceK
13
07-14-2006 08:08 PM
unioncreek
06-29-2005 02:00 PM
Teddy
11-02-2002 01:56 AM
Quick Reply: Zeroing steering wheel?
