Yanmar marine diesels
Old 09-14-2011, 09:38 PM
SORTIE's Avatar
if Yanmar will provide financing, I'm seriously considering re-powering my gasser boat with their mechanical 4JH4-HTE (110 hp) model
their engineering analysis shows a 17 kt cruise at 3,000 rpm (<5 gph) for my boat with that powerplant. WOT would be 25ish
the alternative is a 4BY150 electronic model that would turn more rpms but push the boat along faster
as the owner of a 1st gen CTD and a 1985 Mercedes 5-cylinder mechanical diesel you know I prefer simplicity
does anybody run or know about Yanmar marine diesels?
both of these engines cost almost as much as the boat is worth now...
pic of said boat, weighs 4,500# with a small-block V8 gasser for power. it's no speed demon, but very seaworthy and very fishable...it should have DIESEL power!
Old 09-15-2011, 09:52 AM
SORTIE's Avatar
34 views but no posts, I guess I'm in the wrong place to ask a question about a rice-burning marine diesel
Old 09-15-2011, 10:10 AM
Fiftygrit's Avatar
My brother had one in an old converted troller, worked fine, wasnt the fastest thats for sure, his boat was right around 30 foot and displacement hull. easy on fuel though. Poor old girl sunk.
Old 09-15-2011, 10:42 AM
high bid's Avatar
tons of info...I'm re-installing two Yanmar 6LP-STE in my 35' sportfisher. Post your questions or PM me.
Old 09-15-2011, 12:03 PM
chaikwa's Avatar
A little impatient are we?
I can't answer specific questions, but I CAN tell you Yanmar is a real good engine.
Old 09-15-2011, 12:15 PM
SORTIE's Avatar
what was the previous power and what led you to Yanmar vs. Volvo, Cummins, Caterpillar, Steyr, Man or any other marine diesel?
Old 09-15-2011, 12:17 PM
SORTIE's Avatar
guilty. just wanted to cut my losses if I was BARKing up the wrong tree
Old 09-15-2011, 12:41 PM
chaikwa's Avatar
BARKing up the wrong tree can drive you batty!
Old 09-15-2011, 12:45 PM
SORTIE's Avatar
I don't know BARK but according to DTR reports it seems he has issues
now, back to marine diesels
Old 09-15-2011, 01:40 PM
chaikwa's Avatar
Well, you just ended this thread!
Old 09-16-2011, 09:20 AM
high bid's Avatar
LOL, I've use crapapiller, detroit and cummins. Yanmar has the highest power: < weight: < gph ratio for the price I could afford. I just need a crane to get things finished up. Post any questions and I'll do my best to answer them OR register @ www.boatdiesel.com there is a ton of info there.
Old 09-16-2011, 09:23 AM
SORTIE's Avatar
my main concern is the engineering workup that shows a 110 hp unit pushing my boat along at a higher cruise and WOT than my 305 c.i. V8 gasser...doesn't seem possible
Old 09-16-2011, 12:51 PM
high bid's Avatar
yes, true although it would be helpful if you find a hp/rpm chart for the specific engine your wanting to use. Yanmar are high rev motors and yanmar expects you to run them this way. My 6LPs are built to run 3850 all day long. I'm not sure but look to see if Yanmar has 4cyl engines w/4 valve cyclinders, this will up the hp you may be looking for.
Old 09-16-2011, 02:53 PM
SORTIE's Avatar
their analysis shows the 110 hp pushing my boat at a faster cruise at the same RPMs (3,000). that would be with a fresh transmission with the same 1.25" shaft and a 21 pitch prop (vs. 15 at present)
just doesn't make sense to me
the diesel option is literally 3x as much as a gasser replacement
the Norwalk Boat Show is next week and I'll corner this guy in the Yanmar booth to see if I can make a deal...this mechanical engine is featured on their website under the "discontinued" department
Old 09-16-2011, 03:37 PM
high bid's Avatar
Yes, diesel does cost more but I'm not so sure about 3x. Question.. how long are you going to keep the boat... the diesel repower will keep you going for many more years and provide improved fuel economy but it may not be worth it if you're going to sell within a year or so. Another thing, google search similar size boats as yours that have done diesel swaps/repower. Knowing the length/weight and compare others results will help your decision vs. just going off "their analysis." Honestly, I'd look at rebuilt Yanmars on ebay and not directly from Yanmar. I can see how you're going to pay out the wazooo directly from them. All good questions but I'd research the heck out of it prior to doing the swap. Once committed to the swap you'll have to think about engine mount, alignment, electrical (even though it's mechanical) and gauges. W/my boat, my dad has done most of the work and beared the $$,$$$ expenses, I just have to put it back together!
Quick Reply: Yanmar marine diesels
