XZT and pinging??
Old 09-04-2007, 09:40 PM
iweb's Avatar
XZT and pinging??
Made a trip to Utah and back like I have many times before and this time when the XZT was on and setting and I would WOT it would ping really bad, turn to 0 and none. Did it up and back and with 2 different tanks of fuel. I had the same load, trailer, etc. Never did this before so whats up, why would it do it this trip and not before? Seem like it has a lack of power when it pings?????
Old 09-04-2007, 09:43 PM
qzilla's Avatar
Well, it is not really pinging.
Were you in higher altitude or hotter temps? This will make them sound a little different.
Old 09-04-2007, 09:59 PM
Raspy's Avatar
Check your front fender and see if it says "HEMI". If it says "Cummins" it's something other than pinging. Usually the diesel knock is only loud at idle and only with advanced timing on a CR. Must be something else or WAY too advanced.
John
Old 09-04-2007, 10:09 PM
Spooler's Avatar
I have had mine do that with poor quality fuel and a Rokktech. That is the only thing I can come up with. I changed fueling station to a high volume station and the noise went away along with working the pudding out of the truck every once in a while pulling a heavy load. Howe's Meaner cleaner also helped but working the truck cleaning the carbon off the injectors really does the trick and it's free.
Old 09-04-2007, 10:12 PM
iweb's Avatar
Same temps and did it at high altitude and then again in Vegas on the way home. Its not just a different sound it is a very loud and distinct ping just like a gasser.
Old 09-04-2007, 10:23 PM
scottrod's Avatar
I had an XZT that I had to send back to Quad for a flash. It had so much advance at WOT it sounded like the engine was going to explode. Worked fine after the flash.
Old 09-05-2007, 06:53 AM
GoodOleKyle's Avatar
I have had a similar noise at times. Usually only happens at WOT or close to it pulling a load. I ran some fuel system cleaner through it for about 10 tank fulls and havent heard the noise since....
Old 09-05-2007, 07:48 AM
iweb's Avatar
What brand of fuel cleaner did you use?
Old 09-05-2007, 08:45 AM
i believe it was power service. I cant really remember, got it at Walmart
Old 09-05-2007, 09:45 AM
iweb's Avatar
Fuel might be the answer as it never did this before but its funny that 2 tanks from different states do the same unless the first tank was really crappy. I will do the cleaner and try another fuel station and see if it don't clear up. My tow load was only about 3,000 lbs so it did not get a good work out. Thanks for the info everyone.
Old 09-05-2007, 10:47 AM
jrussell's Avatar
Mine did something like a ping/rattle once with the XZT. I was going uphill (empty) from a dead stop and punched it, then let off a few seconds later. When I let off the RPM's were up there and the tranny was just about to shift. It held the gear when I let off and the motor made a really loud distinct rattle sound just as the RPM's started to drop. It never did it again though even while towing. I figured it was some kind of timing glitch?
Old 09-05-2007, 11:22 AM
During the time my truck was making this loud pinging/rattling, i took the xzt off and sent it to quad for them to check out. Everything on the box was normal, and under the right circumstances my truck also made the noise stock. Ran the fuel cleaner for a little while, then stopped, all is well.
Mine always made this noise somewhere around 22-2600 rpms, had to be in the throttle pretty good to do it.
Old 09-05-2007, 07:53 PM
iweb's Avatar
Bought a jug of silver bottle Klene, do you guys think putting in 32 oz is over kill on one tank? Will it hurt anything?
Old 09-05-2007, 10:08 PM
clarson80's Avatar
I'm sure it won't hurt anthing.
dwhite
58
10-25-2004 05:18 PM
NJMurvin
13
09-24-2004 06:05 AM
dwhite
03-23-2004 05:31 PM
Dodgezilla
02-06-2003 12:56 AM
accordionjohn
11-06-2002 12:11 PM
Quick Reply: XZT and pinging??
