XZT+ and Commander
Old 02-25-2008, 02:35 PM
mattym's Avatar
XZT+ and Commander
Bought them together, vendor said they would communicate with each other.
Before installing, double checked with Quad tech support, they said yes.
Didn't seem to work right, so I called Quad support again, and was told it would be a software update soon. But I found an archive on here from QZilla, saying they worked together. Is anyone using a Commander to change power levels on an XZT+? Don't want to drill a hole for the toggle if this will work, but don't like having the toggle wire wrapped around the shifter either. Not complaining, I know how hard they've been working on the new downloads, just wondering how this is working for anyone else.
thanks
Old 02-25-2008, 05:52 PM
qzilla's Avatar
The Commander works as is. The problem is that the wiring from the Commander to the XZT+ do not match up correct for the data port off of the XZT+.
We are waiting on some wiring adapters to solve this.
Old 02-25-2008, 11:17 PM
Krob's Avatar
I'm using the switch till they get it worked out. You probably have this figured out or your truck may be different but on mine it was.
commander position 0 and 3 were fuel and timing
Commander position 1 and 2 were timing
no off position.
Hope this helps.
Sixpack73
03-15-2007 02:10 PM
truk
01-09-2007 04:24 PM
truk
01-02-2007 07:33 AM
stock03
11-09-2006 11:27 PM
Quick Reply: XZT+ and Commander
