XZT+ 3k Tune
It is different than the COMP Tune and you can only get it by having someone email it to you. I'm sure some others will post up/send you a message about it.
Anyone have an issue w/the dload process? I keep getting an error.."the application failed to initialize." First I tried the beta1 tune and then just tried to reload the 3k tune...and still get the error. Any ideas...Quad is closed on Sat. Thanks.
I mostly run in economy mode anyway
Ok, had to make a pc change. For all of those who've had issues w/the Quad XZT+ box being recognized by your pc, you may want to follow this Windows XP update.
1. Access control panel\system\hardware\device manager
2. Connect the XZT box.
3. After connection, you will notice the usb list expand.
4. Right click on the usb icon and select reinstall/update.
5. Select recommended updates and automatically install
6. When prompted for the file update location , type in "C:\windows\system32\drivers"
This should allow your PC to recognize the Quadzill XZT+ box. Hope this helps with this issue.
Blake Clark
21
08-21-2012 12:35 PM
highrpms
03-16-2008 08:35 PM
