x2 update with xp laptop???
Old 01-03-2008, 08:46 PM
duallydave's Avatar
Question x2 update with xp laptop???
i havent been able to get my x2 to work on my xp laptop,ive been on suport with quad and compaq,tried a milion things but no deal,when i plug it in and look in device manager it shows it in ports but flashes and comes and goes,i googled usb issues and microsoft has a hotfix for some usb issues,its not on thier site you have to request it,i hope to get it tomorow,ll post if it helps,anyone else have any tips?i have updated it on another pc so i know its not a x2 problem,its in the puter somwhere
Old 01-04-2008, 07:23 AM
HOV
HOV's Avatar
I've had the same problem, and all I can say is what works for me is a very specific sequence:
1. Run the update program. Let the update window come up.
2. Now plug in the module
3. Run the update
4. Unplug the module
5. Close the window
Have you tried it in that specific sequence?
Old 01-04-2008, 09:33 AM
welndmn's Avatar
Do you happen to know what version of .net you are running?
Many times you can just remove it, then go back out to windows update and re download it.
Old 01-04-2008, 10:38 AM
ptgarcia's Avatar
My hp notebook with XP Pro acts a bit funny also, but it works. I follow a similar sequence to HOV and start the program before plugging in the X2. Then I update the doo-dad, close the program, and unplug the X2.
Old 01-04-2008, 12:01 PM
duallydave's Avatar
my laptop says version 1.1 but i downloaded the newest 3.5 and im not sure if its installed or not but i did download and followed the instructions.does the x2 show up as a drive under my computer?mne doesnt show up,i can see it in device manager but it flashes and acts weird.ill keep trying,maybe they will get it workin on vista,i have a vista laptop too,but i wont hold my breath,darn vistaaaaa
Old 01-04-2008, 12:25 PM
HOV
HOV's Avatar
If you're taking the time to look for the box under your device manager, you're making things too hard. The on/off/on/off problem happens when the box is connected without the update program running. Has the sequence I described worked for you?
Old 01-04-2008, 05:33 PM
duallydave's Avatar
ya i tried the way you said and it still shows "searching for module"i was hoping the hotfix i got from microsoft was gonna fix it but it didnt,where can i look on the puter to see which version of netframe i have?i downloaded the newest but i dont know if it installed or not,thanx for the tips so far,im pretty stuborn so ill keep tryin hahahaha
Old 01-04-2008, 07:02 PM
06megacabman's Avatar
There are two methods to check the existence and version of the .NET Framework. Either one of these will suffice:
Method 1
Click Start -> Control Panel -> Add/Remove Programs
If "Microsoft .NET Framework 1.1" appears in the list, your system meets the requirement.
Method 2
Click Start -> Control Panel -> Administrative Tools
If "Microsoft .NET Framework 1.1 Configuration" and "Microsoft .NET Framework 1.1 Wizards" appear, then your system meets the requirement.
If the Framework does not appear to be installed, or the older version 1.0 is installed, you need to download and install the latest version.
Run the Windows Update via Start -> Programs -> Windows Update or visit http://windowsupdate.microsoft.com and select the .NET Framework as an optional download.
Also, you can visit http://www.microsoft.com/downloads/ and download the ".NET Framework Version 1.1 Redistributable Package"
Found this with google.
Old 01-04-2008, 08:29 PM
duallydave's Avatar
thanx for the tips 06mega
i checked in add remove programs and it shows frame work 1.1 and sericepack 2 and framework 3.5.so i should be ok in that department.any other tips i can try?thanx guys
Old 01-05-2008, 04:53 PM
Might try uninstalling .net via the add/remove programs and reinstall the latest .net from scratch. At this point thats all I can suggest.
MnTom
08-25-2004 11:19 PM
hotdram
10-10-2003 06:24 PM
LatrobeHO
08-07-2003 07:50 PM
Monty
10-27-2002 08:45 AM
Quick Reply: x2 update with xp laptop???
