X2 Commander M3
Old 01-27-2008, 12:17 AM
RSOPNCO1's Avatar
Question X2 Commander M3
WHEN USING THE COMMANDER TO CONTROL MY X2 I UNDERSTAND THAT I LOOSE THE BOTTOM 2 SETTINGS IF YOU PROGRAM THE THE X2 FOR THE M3 SETTING IT WILL BE ON THE 25HP SETTING WHICH YOU WONT HAVE WITH THE X2 AND THE COMMANDER. SO WHAT DO I DO TO GET THE M3 TUNE FOR MY X2 TO USE WITH THE COMMANDER?
Old 01-27-2008, 08:54 AM
shortbed rv's Avatar
Select which x2 you have and check the downloads.
http://www.quadzillapower.com/upgrades/index.html
Old 01-27-2008, 11:02 AM
RSOPNCO1's Avatar
File Name: 325 STD MPG
Models: X2D0406S
Software Version: 20071004
Feature Code Enabled: 325S_MPG
Features:
* Turns PL1 into Max Mileage Tune
* All other tunes are normal 325 Standard Tunes
* Loses 20hp tune that was in PL1
* Boost Fooling Enabled
Does the PL1 apply When using commander. I understand that it will be put on the 20 hp setting which you don't have witht then commander?
Old 01-27-2008, 04:53 PM
RSOPNCO1's Avatar
bump bump anyone???
Old 01-27-2008, 05:03 PM
On the commander you have level 0=stock, next Level 1 Milage level 2 would be the second highest level and level 3 = highest level.
That is the way I understand it.
stock03
11-09-2006 11:27 PM
Monty
03-31-2004 08:34 PM
Barrett_Fodder
03-03-2004 07:15 PM
rossn2
02-23-2004 07:34 AM
y-knot
0
09-08-2003 05:29 PM
Quick Reply: X2 Commander M3
