What would be the reason for timing jump?
Old 01-18-2008, 07:37 PM
Ru rammin 2?'s Avatar
Angry What would be the reason for timing jump?
I set the timing at 16* this evening and went for a road tese and the truck ran great for the first few miles then it started smoking like crazy and running terrible. It was the first drive with new injectors, timing set, and a govenotr spring kit. I was wondering what the problem was and my brother suggested that the timing jumped. I checked that first and sure enough it was at 3.4 mm I reset it at 16* but haven't started the truck yet. I'm sure that was the problem but I would like some input on what caused it. I torqued it to 150 ftlbs but the nut broke loose real easy. Did I miss something? The thrust washer was still there and looked fine. Could I have a bum torque wrench?
Old 01-18-2008, 07:55 PM
DTR's Toad Wrangler
Clayten's Avatar
Did you clean the oil off of the gear and shaft?
Old 01-18-2008, 08:21 PM
As best as I could. I didn't want to get too wild since the contaminates go into the oil.
Old 01-18-2008, 08:27 PM
dieseldemon's Avatar
Use brake clean it vapors out when the oil gets warm and torque the nut to 165 I have never had one come loose yet
Old 01-18-2008, 08:40 PM
I retimed it just now and torqued it tighter than the 144 and it seems to be holding. I might recheck it tomorrow.
Old 01-18-2008, 10:19 PM
dieselman2300's Avatar
Did you use a NEW lockwasher? A 20mm lockwasher from any hardware store works.
Old 01-19-2008, 12:32 AM
Tate's Avatar
Like was said, make sure shaft is clean (brake clean or some contact, No Flash works AWESOME), torque the shaft to 140, then to 160, then I go to 180. No slippage yet.
Old 01-21-2008, 02:19 PM
I didn't use a new lock washer. none of the instructions I found said anything about the new lock washer. I put a hundred or so miles on it and it is still running fine. I might check it when I do my dad's but it seems to be fine. I torqued it to probably 165-170 in 3 or 4 stages and it worked fine, but thanks. Now I know.
HsOffRoad
08-02-2013 06:06 PM
92smokin blacky
02-23-2011 07:18 PM
93Fury
09-13-2010 11:16 AM
Pav1973
105
12-09-2007 12:06 AM
livewire
04-19-2006 10:31 PM
Quick Reply: What would be the reason for timing jump?
