Would this help to keep the engine warm?
I don't suffer the cold as much as the guys up north but I have been wondering about this for sometime. The auto tranny has a heat exchanger that has engine coolant running through it and a transmission cooler just behind the grill. Would it help with warm up if you just blocked the air to the cooler behind the grill? The ice cold air running across that outside cooler may be helping to keep the engine cool because the other heat exchanger will have ice cold tranny fluid running through it. In the winter my trans temp bearly moves off the peg.
I have even thought of getting a oil bypass thermostat from Summit for about $55 US and installing it so the outside cooler is bypassed until the fluid hits 175 degrees F. I think it would help in the less extreme cold but not too sure if it would when it gets below zero.
I like the idea, although trans fluid is usually higher than your antifreeze and that unit is supposed to be a cooler.
All i can think of is that cold fluid rushing its way to your hot trans when the temp switch opens. The only thing i can compare this to is the horrible rattle sounds in old houses when you turn the hot water in the shower on full blast... the hot and cold rush by each other causing pressure differences enough to rattle the pipes in your walls.
How about that uncontrollable shiver you have when you are in shock when your knees are shaking and your teeth are chattering or when you had just fallen into icy cold water.
Think I have experienced at least one of them.
This kind of rattling?
mtb1982
55
Jan 20, 2020 10:45 AM
sleepr tsi
Sep 9, 2007 01:15 AM
