Will this work and will it void warranty?
Old 10-19-2005, 04:40 PM
texasredrider's Avatar
I have about 7000 miles on my truck and have been very strict in what mods I do in regards to the factory warranty. I have heard of this:
http://www.rokktech.com/_mgxroot/page_10437.html
And I have read the posts about this Rokkteck crankshaft sensor but have not seen a post that addresses this.
Will this void my warranty since I'm sure the computer will record a +2 degree change in the timing and will be detected if pulled up? OR---Does the Dodge specs specify + or - 2 degrees in which case it would be OK (within spec).
If its safe as far as Dodge warranty concerns, it will be a mod that I would do. Big " if " though
Old 10-19-2005, 05:26 PM
MikeyB's Avatar
Guess it could void the warranty. But Dodge would have to remove the sensor to even tell it was modified. And the computer wouldn't detect a 2 degree change.
MikeyB
Old 10-20-2005, 02:29 AM
TexasCTD's Avatar
So does putting this Rokktech sensor on the truck do the same thing as the Tone Ring mod I keep reading about? Or is this something you can or may do in addition to it?
Old 10-20-2005, 07:09 AM
MikeyB's Avatar
Yes, the tone ring mod does the same timing advance as the Rokktech sensor.
MikeyB
Old 10-20-2005, 12:52 PM
TexasCTD's Avatar
Thanks MikeyB,
I sent them my number to contact me. If the Sensor will do the same thing, I feel a little more comfortable putting it on rather than pulling the ring off and cutting it out, etc...and fighting with the bolts, etc.
Sounds like I can just keep my stock sensor, and put it back on if I ever go to a box that adjusts timing/duration etc....in the future. Am I right? Then it wouldn't over advance the timing and cause problems.
Old 10-20-2005, 12:58 PM
Thats MR Hoss to you buddy!
Hoss's Avatar
MikeyB
With the added benefit that it's FREE.
Old 10-20-2005, 01:04 PM
MikeyB's Avatar
Originally Posted by TexasCTD
Thanks MikeyB,
Yes, you could put the original sensor back on if going to a box that does timing or you can adjust the Rokktech back to the stock position.
MikeyB
Old 10-20-2005, 01:25 PM
TexasCTD's Avatar
MikeyB
Thanks again MikeyB,
I will order one as soon as they call me. Be nice if they had a phone number on their website for me to call. If they did, I didn't see it.
rkelley
10-12-2006 06:59 AM
Copenhagenjunkie
01-23-2004 07:04 PM
Shaders 24v
08-27-2003 09:55 PM
clydesdale6
02-28-2003 09:50 AM
latitud_rt
40
01-28-2003 10:05 PM
Quick Reply: Will this work and will it void warranty?
