Witch Gauges are More Imporant
Old 08-18-2007, 02:46 PM
Huntnrg's Avatar
Is boost pressure that important to monitor if your running stock turbo?
I,m going install an ISSpro 3 gauge A-pillar with Pyro,Trans,& fuel pressure.
Need advice!
Old 08-18-2007, 03:24 PM
Registered
blackdiesel's Avatar
the boost pressure IMO is one of the least needed gauges. However, it does make troubleshooting boost leaks rather easy.
the pyrometer, trans temp (for an auto) and fuel pressure (exp. for a 24v) are the 3 most important. So go ahead and get them
Old 08-18-2007, 03:32 PM
XLR8R's Avatar
The boost gauge isn't the most important - it's just the most fun to watch!
.... until you get a TIP gauge.
Old 08-18-2007, 04:07 PM
1BAD4X4's Avatar
When I bought my truck it only had a Fuel pressure gauge mount on the A-pillar. So I got a dash mounted 3-pod holder. I like it b/c its different then most others... everybody and their brother runs the A-pillar. So now I'm able to monitor Fuel pressure, boost, trans temp, and EGTs.
I know I've seen trucks with more then 4 gauges... what are some other commonly monitored things?
Old 08-18-2007, 04:13 PM
XLR8R's Avatar
... with this many gauges - whatever you want!
Old 08-18-2007, 04:52 PM
Tate's Avatar
Is it just 9 gauges, or is there more I'm missing?
Old 08-19-2007, 12:30 AM
XLR8R's Avatar
Well, just 12 (2 digital) we installed inside the cab (TIP gauge not shown in this photo), but 4 more under the hood.
Old 08-19-2007, 01:00 AM
Cougsfan's Avatar
just what all do you monitor with all them gauges??
Old 08-19-2007, 01:38 AM
Dr. Evil's Avatar
Id like to know how he reads the ones under the hood...
Old 08-19-2007, 10:48 AM
XLR8R's Avatar
... that's why you DON'T want to be the smallest guy on our pit crew! (no wonder we had to shield the Race box's harness - too much EMI from the cell phone of the poor slob stuck with "underhood duty" )
Cougsfan:
Fuel Pressure
Intake Boost
EGT
Hot Pipe Temp
Rail Pressure
Drive Pressure
Oil Temp
Hot Pipe Boost
Tranny Temp
Oil Pressure
Water/Meth Pressure
Diff Temp
Hobbs Pressure
Airhorn Temp
LineLok Pressure
Coolant Pressure
Hmm - seems like there was another one!?
Old 08-19-2007, 04:57 PM
1BAD4X4's Avatar
Wow... although I don't see how you could actually read the ones on the right of the dash either though.
Old 08-19-2007, 07:03 PM
XLR8R's Avatar
They're well within my peripheral vision.
Old 08-19-2007, 10:27 PM
junkyard's Avatar
you guys are all nuts. you know that...right?
Old 08-20-2007, 07:56 AM
XLR8R's Avatar
... yeah - just your average TruckNutz
flashgordon
05-03-2006 05:08 PM
flashgordon
04-30-2006 09:05 PM
puffmagicdiesel
03-21-2006 02:40 PM
tinman1911
05-27-2005 11:06 PM
Dieselbuilder
11-11-2003 06:51 PM
Quick Reply: Witch Gauges are More Imporant
