wiring problem
Old 12-02-2008, 08:25 PM
loch's Avatar
wiring problem
hey guys i have a question, i have a 2001 and my signal lights and brake lights are working. Is this a common problem ? could someone point me in right direction please.
Old 12-02-2008, 08:50 PM
dozer12216's Avatar
Need to proofread. I assume lights are not working!!!! Check fuses. Do marker lights and front signals work? Suspect TS switch for brakes and turn signals.
Old 12-02-2008, 08:56 PM
loch's Avatar
sorry not enough info, everything works but signal and brake lights, all fuses are good.
Old 12-03-2008, 10:59 AM
infidel's Avatar
My bet is it's a fuse you missed.
You can't always tell by looking.
Buy a tester from the autoparts. They sell one that tests the fuses in place, no need to pop them out, for under $10.
Don't forget to check under the hood.
Old 12-03-2008, 03:52 PM
ironbutt's Avatar
Also check all body grounds on the bed, and the one that goes bed to cab. Don't trust the look, loosen it up,then re-tighten . A bad chasis ground will play heck with the tail lights.
Old 12-03-2008, 06:08 PM
loch's Avatar
ok i hang out in first gen area im new to these trucks, i didnt realize there were fuses under the hood, i did use a checker on fuses inside the cab. but there is no fuse labled stop or brake or signal inside.
wyododge
01-13-2009 02:25 AM
Evildiesel
07-02-2006 06:39 PM
charcoal600
04-30-2005 02:34 PM
jeffket
06-12-2004 11:07 PM
Caincando1
02-23-2004 03:52 PM
Quick Reply: wiring problem
