wiring a overhead console
Old 02-12-2004, 05:06 PM
oakland1964's Avatar
I bought a overhead console w/computer off of e-bay. Does anyone have the wiring diagram or can tell me how to wire it into my 2002 Ram ?
Old 02-12-2004, 10:56 PM
kingofdodge7131's Avatar
Not 100% sure, but i think there plug and play morel ess arnt they> just plug into the connector?
which should already be htere. But i could be wrong, Ill check monday when i go back to school
Old 02-13-2004, 02:11 PM
cfar's Avatar
you will need two wiring harnesses and the temp sensor.
One harness goes from the overhead console(attaches to upper harness) to the bottom left of the fuse box, and a plug near the bulkhead connector(dual ended).
The other harness will go from near the light under the hood to the temp sensor, which you will have to mount.
Temp sensor - #4688204 $16.10
Temp sensor jumper wire - #56021994AB $21.60
Upper harness (inside console) - #50130608AA $32.85
Lower harness (from console to fuse box) - #56045921AC $57.45
Of course this was a couple of years ago.
If you bought a console with trip computer, then you probably have the upper harness, it will plug into the trip computer and the lights.
any questions ask away.
lol
Old 02-17-2004, 12:14 PM
cmckinney's Avatar
You know I did not see any pre-wiring for my 2002 overhead console for the display.
Oakland1964, Did your 02' have the wiring? This inquiring mind wants to know.
Cholmes
29
03-29-2012 12:38 PM
BlackSheep5
12-20-2007 03:26 PM
Valv
06-26-2007 06:56 PM
durasmack
01-23-2006 06:23 PM
Quick Reply: wiring a overhead console
