Wiring in Off Road Lights
I built a light bar for my truck and I want to wire in the lights to come on with the high beams. I want to use the dimmer switch to trigger the relay for my off road lights. What wire should I use as a trigger?
Thanks,
Richard
Thanks,
Richard
You may want to check your local laws. Here it is illegal to run offroad lights on the street. You could run it though a main on/off switch and still trigger them the high beams just in case.
I pulled control power off the high beam circuit right at the bulb. It runs through a switch that supplies the control side of the relay for the lights. That way they will only come on if high beams are on, but I can turn them off if I don't want them with the high beams.
Tap power from high beams to power a relay. Switch this power as well. Then you can have high beams with or without your offroad lights. I have been running a set of lightforces this way for years.
Tap off one of the high beam wires like other have said. But run the ground (-) wire for the relay to a switch mounted in the cab. This way you only have to run one wire inside the cab and you don't have to worry about fusing it like you would a hot (+) wire. Then just a short jumper wire off the switch to a ground location close to your switch.
If you really wanted to get yourself in trouble, run a 3-way switch and put a blinker relay on the other side... So then you have "on-off-flashing" options... great for road side safety reasons...
bandit1trucking
02-14-2019 08:16 AM
dtc503
11-12-2005 11:20 PM
Bowman
10-16-2004 06:49 PM
