PDA
View Full Version : Wiring colour codes for remote starter
Ruadh
11-04-2002, 11:54 PM
Good evening gentlemen. <br>Would any of you who have installed a remote starter on your truck happen to have the colour codes for the various wires involved under the dash? Mine is a 2002 and I am putting in a remote starter next weekend and it would sure make it a lot easier if I knew in advance which wires to look for. <br>I'm also putting in a &quot;high idle&quot; box and I think I have a way to tie the two together. I'll let you know if it works out. <br>Thankx<br>Ruadh
BigBlue
11-05-2002, 05:28 PM
Where did you get the remote starter? I've been looking for one.
Workin Man
11-05-2002, 05:50 PM
Ruadh<br><br>Bought one for my wife for Christmas a couple of years ago. Forget who made it, but logged onto their website and they had a support section secifically for this purpose. Enter your year, make, model and options and it listed all of the color codes and on which connector to find them. Try it for whoever makes your unit, they may have something similar. I paid $60 Canadian for that unit at Walmart, so I would guess if they deliver that kind of support, a higher end manufacturer would at least match it.
SirLAL
11-05-2002, 06:08 PM
A local company installs these for under $500 Canadian<br><br>www.ultrastarters.com/index2.html
Commatoze
11-05-2002, 06:29 PM
Ruadh, I think I got this for you. The wires color are directly from the connectors up by the ignition switch.
There's a 4 position, and a 7 position connector.
4 Position:
1 22 ga Black/Orn - Ground
or depending on options
1 22 ga - Tan Driver Door Ajar sense switch
2 22 ga Lt. Blu - Key in Ignition switch sense
3 empty
4 empty
7 Position:
1 14 ga Yellow - Ignition Switch Output (Start)
2 12 ga Dk. Blu - Ignition Switch Output (Run-Start)
3 blank
4 14 ga Pink/Black - Fused B+ (12V)
5 14 ga Black/Orn - Ignition Switch Output (Run)
6 12 ga Black/Wt - Ignition Switch Output (Run-Acc)
7 10 ga Red - Fused B+ (12V)
Hope this helps you out.
-Tom-
Ruadh
11-05-2002, 08:49 PM
<br>Where did you get the remote starter? I've been looking for one.<br><br><br>I live in Edmonton, Alberta and I bought it at a place called Dash Distributers. $139 CDN for the Ultrastart 2250M. It is an alarm and remote combined.
Ruadh
11-05-2002, 08:51 PM
<br>Ruadh<br><br>Bought one for my wife for Christmas a couple of years ago. Forget who made it, but logged onto their website and they had a support section secifically for this purpose. Enter your year, make, model and options and it listed all of the color codes and on which connector to find them. Try it for whoever makes your unit, they may have something similar. I paid $60 Canadian for that unit at Walmart, so I would guess if they deliver that kind of support, a higher end manufacturer would at least match it.<br><br><br>Thankx Workin Man. I tried the Ultrastart website and couldn't find anything specific to the Cummins and Dodge.<br><br>Ruadh
Ruadh
11-05-2002, 08:54 PM
<br>A local company installs these for under $500 Canadian<br><br>www.ultrastarters.com/index2.html <br><br><br>Thankx SirLAL<br><br>I paid $139 CDN for the Ultrastart 2250M and my son will install it for me. He's done several and he's an electronic tech so I'll be OK.
Ruadh
11-05-2002, 09:01 PM
<br>Ruadh, I think I got this for you. The wires color are directly from the connectors up by the ignition switch.<br><br>There's a 4 position, and a 7 position connector.<br><br>4 Position:<br>1 22 ga Black/Orn - Ground<br>or depending on options<br>1 22 ga - Tan Driver Door Ajar sense switch<br>2 22 ga Lt. Blu - Key in Ignition switch sense<br>3 empty<br>4 empty<br><br>7 Position:<br>1 14 ga Yellow - Ignition Switch Output (Start)<br>2 12 ga Dk. Blu - Ignition Switch Output (Run-Start)<br>3 blank<br>4 14 ga Pink/Black - Fused B+ (12V)<br>5 14 ga Black/Orn - Ignition Switch Output (Run)<br>6 12 ga Black/Wt - Ignition Switch Output (Run-Acc)<br>7 10 ga Red - Fused B+ (12V)<br><br>Hope this helps you out.<br><br>-Tom-<br><br><br>Thank you very much Tom. <br>This will help a great deal. You don't happen to know the colour of the wire for the &quot;Wait to start&quot; light, do you? My son uses a lot of timers on his alarm systems and I'm going to use one to energize the &quot;high idle&quot; circuit after about 3 minutes. That way the engine can get oil pressure before it idles up and save the push rods.<br><br>Ruadh<br><br><br>
yomitch
11-06-2002, 12:12 AM
I had a lady ask me to put one in her husbands truck (as I'm an electrician) for x mas one year and B4 I opened the box I asked her if mit was a standard or auto tranny and she told me that it was a standard which you can't do in a standard!<br> Hope you don't wake up early cuz your neighbours won't like the noise!
Commatoze
11-06-2002, 06:05 AM
Ruadh, I will check this evening when I get home from work and post it for you. That will be easy to find.
hellotbone
11-06-2002, 07:00 AM
there is a site with a forum and all install diagrams its <br>http://www.the12volt.com <br>just sign up and u can post and ask what you like used it a bunch of times. Make sure when you get into your truck you know that you need a tach signal to run the remote start and its a darn b*tch to find with no coil!
Commatoze
11-06-2002, 07:07 PM
Ruadh, the &quot;Wait To Start&quot; wire is connected to connector C1, pin 8 of the instrument cluster. It's an 18 ga Orange wire with a Black stripe (ORN/BLK). It connects directly the the ECM connector, pin B37, so you can get to it from under the hood if deisred. Be careful because there's a Black wire with an Orange stripe on the cluster too (GND).
-Tom-
Ruadh
11-07-2002, 08:33 PM
<br>I had a lady ask me to put one in her husbands truck (as I'm an electrician) for x mas one year and B4 I opened the box I asked her if mit was a standard or auto tranny and she told me that it was a standard which you can't do in a standard!<br> Hope you don't wake up early cuz your neighbours won't like the noise!<br><br>Thankx Yomitch<br>I park a ways away from the appt. so the noise isn't bad at all. I haven't had any complaints anyway. <br>As far as the std. tranny goes, this remote is made just for a std. and has an interlock with the emerg. brake. <br>I think it'll be fine.<br>Ruadh<br>
Ruadh
11-07-2002, 08:44 PM
<br>there is a site with a forum and all install diagrams its <br>http://www.the12volt.com <br>just sign up and u can post and ask what you like used it a bunch of times. Make sure when you get into your truck you know that you need a tach signal to run the remote start and its a darn b*tch to find with no coil!<br><br><br>Thankx Jamie<br>That looks like a great site. My young fella will like it too. <br>Thankx again<br>Ruadh
Ruadh
11-07-2002, 08:46 PM
<br>Ruadh, the &quot;Wait To Start&quot; wire is connected to connector C1, pin 8 of the instrument cluster. It's an 18 ga Orange wire with a Black stripe (ORN/BLK). It connects directly the the ECM connector, pin B37, so you can get to it from under the hood if deisred. Be careful because there's a Black wire with an Orange stripe on the cluster too (GND).<br><br>-Tom-<br><br><br>Well Tom<br>Thankx again.<br>You certainly know your way around the wire, don't you? What do you do to gain all this knowledge?<br>Ruadh<br>
Commatoze
11-07-2002, 08:52 PM
I sleep with the service manuals, Ruadh! ;D Seriously, they are invaluable if you need to find anything. $150 US for the complete set of books, or $90 for the CD's. You can order them from the Chrysler web site.<br><br>-Tom-
Ruadh
11-07-2002, 09:00 PM
Might just have to do that, Tom.<br>If I'm going to do a few things to this truck over the next year or so, it certainly would make life more fun.<br>What do you think of my idea to tie a high speed idle box into the remote starter?<br>Ruadh<br>
Commatoze
11-07-2002, 09:05 PM
<br>Might just have to do that, Tom.<br>If I'm going to do a few things to this truck over the next year or so, it certainly would make life more fun.<br>What do you think of my idea to tie a high speed idle box into the remote starter?<br>Ruadh<br><br><br><br>Sounds interesting and would be curious as to how you think you'd do it. I've heard that you can tie 2 terminals of the ECM together to raise the idle. It's normally used in conjunction with the PTO in the HD Transfer case. DOn't know the detail though. Also, you can have the dealer re-flash your EEPROM with a high idle mod.<br><br>-Tom-
Ruadh
11-07-2002, 09:21 PM
Ya They'll re-flash it all right. For a weeks wages.<br>As to the high sped thing. There is a mechanic at the local diesel joint who has made and markets his own high speed box. Costs $350 or so CDN. What I plan on doing is to use a delay relay tied into the 'wait to start light'. The relay takes a momentary power signal to close the circuit and has a 3 minute delay. I'll connect the relay to the high speed box. After the 3 minute delay, the switch will close and activate the high speed. Simple, yes, no?<br>I'm also using a double throw switch so I can turn on the high speed when I'm out of the truck tieing down the load.<br>Ruadh
SirLAL
11-10-2002, 10:00 PM
Ruadh, I was thinking kind of the same thing as you for the high idle but haven't decided on what high idle method to go, either the pto wire or the high idle boxes. I'm also from the Edmonton area so could you post the name of this diesel joint that sells these high idle boxes, because I'd like to check it out. I asked the dealer about it a month ago and they said there is one that hooks into the cruise control, but $500 is too much, yours sounds better and I don't mind extra switches on the dash ;D
