wiring a 12 valve
Old 12-14-2011, 11:42 PM
jayhoo's Avatar
wiring a 12 valve
how do i wirer a 1994 12 valve to start it befor i buy it . its in a fram it has no body but has fule tanke its a 5 spd i just want to see it run
Old 12-15-2011, 12:07 AM
green95's Avatar
all u need is fuel to the injector pump,and a way to crank the motor. u could hook up a jug with a line to the pump and gravity feed,and use some jumper cables on the starter to turn it over
Old 12-15-2011, 12:17 AM
j_martin's Avatar
uh.......I think you need to get power to the fuel shut off solenoid,
Old 12-15-2011, 07:25 AM
jstone44720's Avatar
You can hold the solenoid up by hand, or wire tie it, but yes you need to either open it or bypass it.
Old 12-15-2011, 07:55 AM
patdaly's Avatar
Yep, duct tape and baling wire are your friends..........
Pull the lever up and spin her over, she will fire off if there is fuel.
Old 12-15-2011, 11:20 AM
Robert Rausch's Avatar
Until I installed a push-pull cable I carried a small piece of 2X4 in my truck that was the exact size needed to hold the fuel solenoid up. Worked like a charm the times the solenoid puked out.
Old 12-15-2011, 06:52 PM
jayhoo's Avatar
thanks
Old 12-15-2011, 07:07 PM
Tate's Avatar
I'd much rather just remove two small bolts and pull the shut off solenoid out than mess with bailing wire or duct tape.
Old 12-16-2011, 07:36 AM
patdaly's Avatar
I must have too big of hands then. I get cut up pretty good trying to pull my solenoid.......
wyododge
01-13-2009 02:25 AM
j20m715
06-13-2007 07:39 PM
Evildiesel
07-02-2006 06:39 PM
charcoal600
04-30-2005 02:34 PM
Quick Reply: wiring a 12 valve
