Wire Tapped Box Problems Need Input Quick
Old Oct 14, 2007 | 01:41 PM
91rangerturbo's Avatar
I am having problems with my Haisley Machine JVD Torque Enhancer. The box is flashing when it should be a solid color. And it is not making any power.
What kind of voltages should i be seeing with the key on and the engine off. Or should i check with the engine running?
The box taps into the injection pump and another wire by the injection pump. I am sure all tapped boxes would be about the same wiring.
I tried reconnecting my box and it seems like it is still doing it. I don't think i have a short but maybe a bad box altogether. Is there any way to verify for sure?
Thanks DTR
Old Oct 14, 2007 | 03:30 PM
anyone care to chime in on this?
Old Oct 15, 2007 | 06:50 AM
anyone care to chime in on this? I can't get no help from haisley machine.
Old Oct 15, 2007 | 06:52 AM
graphitecumnz's Avatar
Never even heard of this box....
What type of connections did you make at the injection pump and others?? Many have reported issues when using posi-taps and the like. I soldered the connections for power, ground and pump tap on my TST Comp.
Old Oct 15, 2007 | 07:58 AM
I was kind of dreading soldering these wires together. Because the injection pump wire is a pita to get to. I guess i will dedicate my afternoon to soldering and report back if that fixes my problem.
Old Oct 15, 2007 | 12:14 PM
It's somewhat difficult to solder the pump wire but it's worth it IMO. I used liquid electrical tape to cover my connections as well.
Old Oct 15, 2007 | 01:30 PM
AlpineRAM's Avatar
If you did just install it do a double check that you tapped the correct wire!
Old Oct 15, 2007 | 02:01 PM
nope the box has been installed for quite some time now. It happened before but it was a loose connection. It like the box is getting power but something is wrong with the box. Oh well i am going to solder it up tonight and see for sure.
Old Oct 15, 2007 | 07:05 PM
that cured my problem by soldering the connections. I need to pickup some of that liquid electrical tape. Never used it or seen it though.
Old Oct 15, 2007 | 10:21 PM
hink's Avatar
Someone told me that Haisley just quit messin with these boxes. Why, I don't know. They work good when they work right though. Glad to see ya got it fixed. The few of these boxes that I've seen are very finicky about having a good tap connectioin.
Old Oct 15, 2007 | 10:30 PM
Glad that you found and fixed your issue... you should be able to pick up the liquid electrical tape at WalMart....
Liquid Tape
Old Oct 16, 2007 | 06:45 AM
Originally Posted by hink
Someone told me that Haisley just quit messin with these boxes. Why, I don't know. They work good when they work right though. Glad to see ya got it fixed. The few of these boxes that I've seen are very finicky about having a good tap connection.
Yeah it was a really problem if you had the slightest connection problem. It won't happen again though it is good to go.
I have talked to haisley about this box before. They told me that the reason the box is dis-continued is because of the after market box support that is out there. Like Edge,BD, etc.. Haisley are big in the machine department.
Old Oct 16, 2007 | 06:46 AM
Liquid Tape
thanks for the link.
DieselDiehard
Dec 28, 2005 06:33 PM
bws
Apr 3, 2005 08:56 PM
I SPEED
Nov 5, 2004 06:13 AM
mooseman
20
Mar 31, 2004 04:16 PM
TPilaske
16
Nov 22, 2002 08:15 PM
