wipers quit
It is probably the wonderful little plastic clips that hold the linkage together. Bearkiller did an excellent post on that, just did mine a couple weeks ago. i just did a advanced search on this site and put in wipers as the key word. Wasn't very hard or expensive (I think $6 dollars for the clips from napa). Hope this helps
Run a jumper wire from the motor to ground that is probably the problem. There is a metal tab tba goes under one of the mounting bolts for ground. Try to tighten that bolt and see if it fixes the problem.
