winter oil
Old 12-02-2005, 06:47 PM
Cummins Freak's Avatar
winter oil
what weight oil should i use in the winter i normaly run a 15-40 moble delvac 1500 but the truck runs so hard would 10-13 10-40 be ok i dont know what do you guys run
Old 12-02-2005, 08:14 PM
Fueling around's Avatar
5W-40 Delvac 1 Synthetic gets my nod. I run it year around.
Mobil 1 15W-40 Truck & SUV oil is very similar.
Many quality CI-4 5W-XX synthetic products will suffice if you only want it in the winter.
10W-40 is gasser oil
I tried a 10W-30 one winter and it wasn't much different than 15W-40
Old 12-02-2005, 08:16 PM
thanks where ya getting the Delvac 1 syn
Old 12-02-2005, 08:18 PM
Captain's Avatar
I personally like rotella. I run 15-40 most of the time since its half the price and not synthetic. However its only good down to 10degrees F befor I have to start plugging it and what not. Rotella also has a 5-40 synthetic that has all the same API certs but is good down to -20degrees F. I got that number directly from rotella. It is however twice as muchmoney. about 15$/gallon here.
Old 12-02-2005, 09:13 PM
A guy that used to live in the area located it at a local petroleum distributor in Grand Forks.
I'll have to contact a buddy of mine in Bismarck for your local source.
I read that Wally World carries the Truck & SUV 5W-40 and possibly the Rotella synthetic. Don't shop there so cannot say.
Old 12-02-2005, 09:23 PM
no rotella 4 this guy truck just burns it up
Old 12-03-2005, 05:58 AM
russ300h's Avatar
Rotella is a group III synthetic, Mobil is about $1 qt. more, but a group IV. Mobil is a true synthetic, the Rotella made with some conventional oil components. Without getting technical, the Mobil is far superior for a modest price increase.
Old 12-03-2005, 08:32 AM
Dr. Evil's Avatar
Great first post Russ - Mobile 1 is a great oil
Old 12-03-2005, 08:33 AM
infidel's Avatar
I run Delo 15w40 year round but when it gets below 20F plug in an oil pan heater along with the block heater. Been working just fine on both my rigs for over 200k each and ten winters.
Do this mainly because I buy Delo in 55 ga drums and don't want to stock other oils but also because in my area it's very typical for temps to go from minus 20 to over 60 in one day and stay there.
Don't feel that lighter oil would do the job with warmer temps.
Old 12-05-2005, 06:27 PM
Rare1's Avatar
Your OWNERS MANUAL will tell you exactly which oil to use depending on usage and temperature. Basicly 15-40 diesel rated but for cold weather cold starts best to use a synthetic.
Old 12-05-2005, 08:39 PM
A & I Distributors
1721 Michigan Avenue, Bismarck, ND 58504
(701) 222-8790
Old 12-05-2005, 09:13 PM
WideOpenThrottl's Avatar
I run amsoil 15w-40, its spendy, but i put 13-15k on oil changes and works great in the winter. Truck always starts, and hardly ever gets plugged in .
tim
Old 12-06-2005, 08:52 AM
DIESELRYAN3500's Avatar
I Have Been Using Lucas Magnum Truck Oil 15-40 With Good Starting In Cold Weather....never Pluged In, Then Again It Never Gets Below 28* Around Here
Tedonlin150
46
11-21-2011 10:45 AM
ozzie
25
01-17-2004 02:30 PM
10-13-2003 08:19 PM
wheels
16
11-15-2002 10:46 AM
Quick Reply: winter oil
