Window Regulator Bushing
Old 10-01-2009, 11:19 AM
XLR8R's Avatar
Anyone ever been able to source one of these white plastic bushings that capture the X-arm's ball-end inside the track?
Don't want to buy a whole regulator for a 7 cent bushing...
TIA
Old 10-07-2009, 07:47 AM
just_crankin_it's Avatar
i just went through this a couple months ago. i couldn't find one either and "rigged" a small screw and washers to ride in the rail. it's been a few months and have no problems. i found it easier to do this by taking out the entire regulator.
Old 10-07-2009, 09:02 AM
XLR8R's Avatar
How did you keep the lift-arm's ball end captured inside the track?
Old 10-07-2009, 09:18 AM
I will try and take a picture and post during lunch. Not saying it was the best fix but worked for me
Old 06-29-2010, 12:03 PM
Snapper's Avatar
hmmm never took a icture eh??? lol. I just noticed my window had alot of excessive play while moving down and found out that plastic bushing has broken for me. anybody found a plastic piece yet?? might have to go junkyard playin...
Old 06-30-2010, 02:36 PM
jcw74801's Avatar
I cut a piece of rubber fuel hose and popped it onto the ball then forced it into the channel. To my surprise it has actually been working for a few months now. I don't have a picture either.
Old 07-02-2010, 06:40 AM
Snapper's Avatar
I like the fuel hose idea. I'm gonna try that and see.
Old 07-28-2010, 10:50 AM
HTRDNCK's Avatar
Mine just broke as well. Haven't been able to find the bushings at the dealer or local parts houses, anyone ever have any luck with this?
Old 07-28-2010, 11:34 AM
jcw74801's Avatar
After several months mine popped out again. The piece of fuel hose was coming apart on the outside from rubbing in the track. So I greased up the track real good and installed a fresh piece of fuel hose. I'm not sure what diameter it is but the ball pops into it fairly snug. Maybe a drop of glue or RTV would help make it stay in. But it works great. If I have to fix it once or twice per year that would be o.k.
Old 07-28-2010, 12:20 PM
HTRDNCK's Avatar
I'm going to try your solution until I can hopefully find the parts.
Thank you for the update. I was curious as to the durability of it.
Old 07-31-2012, 12:16 PM
Grider Pirate's Avatar
Window regulator bushings
I'm resurrecting this thread because it just happened to my truck. My own fault. I was ****** off about something and slammed the door. Next time I went to lower the window, it moved normally for about 2 inches then dropped. I took the door inner panel off, and could clearly see the broken nylon bushings sitting in the bottom of the door.
If someone has found a source, please post up! Otherwise, I will try have some produced by one of the many companies that do '3D printing'.
Jim
Old 08-01-2012, 08:02 AM
Greg Reed's Avatar
I don't remember which forum it was on, I read a thread where someone used a plastic roller from a shower door. Probably had to remove the stud as they are mounted with a screw. I'll try to find the writeup.
Old 12-13-2012, 11:58 AM
Smile Ebay to the rescue
I gave up trying to find or fabricate new nylon bushings. My favorite Ebay vendor of Dodge Ram parts had two regulators (minus motors) for $26.(ish) including shipping. All good now!
Old 12-13-2012, 02:20 PM
Redlinear's Avatar
$26ish? This means war!!
Old 12-14-2012, 03:16 PM
SIXSLUG's Avatar
Try www.clipsandfasteners.com.
They have a "glass shop supplies" page that has a lot of window regulator and trac parts....
Quick Reply: Window Regulator Bushing
