Window Problems
Old Dec 29, 2011 | 08:09 PM
younggun95's Avatar
Window Problems
the windows were working on the truck and then we noticed that they stopped working a couple days ago. we checked the fuses and they were fine. any ideas on what happened or how to fix the problem?
Old Dec 29, 2011 | 08:19 PM
jerseybud's Avatar
Check your fusible links, then your wiring/switches
Old Dec 29, 2011 | 08:56 PM
younggun95's Avatar
thanks i might do that tomorrow when there is some light. ill let you know if that works
Old Dec 30, 2011 | 04:41 AM
Andy505's Avatar
The 93 I used to have had a mechanical issue and the window was stuck all the way open. I had to take the door panel off and put the window back on the track and weld a stop in the gear that controls window movement.
Old Dec 30, 2011 | 09:22 AM
ppiggppenn's Avatar
My power window problem turned out to be a faulty switch, ...
Old Dec 30, 2011 | 09:26 AM
gyman98's Avatar
Check the wiring between the door and jamb also, very common for them to break in there
Old Dec 30, 2011 | 10:40 PM
younggun95's Avatar
thanks those could help out because we still are wondering what happened because they had been working
DJ Turbo.
Oct 13, 2011 09:11 PM
Jklawinsky
Jul 28, 2011 11:42 PM
Rednecktastic
Aug 29, 2010 11:26 PM
raven392003
Oct 29, 2007 11:39 AM
tcr
Aug 8, 2005 05:36 PM
