Why are my egts high?
Old 01-29-2008, 09:17 PM
sallyman1's Avatar
Thumbs up Why are my egts high?
I have ****** whistler intake, Stock 4" exhasut from turbo back with exception of aero4040xl in place where cat was. I just installed juice attitude. On settings 0-6 i get high egts. I have my alarm set at 1450 and my max egt set at 1300.
When cruising at highway speeds (60mph) and I go out to pass a vehicle and press fuel pedal about half way down the alarm beeps after a few seconds. i can see 1400 ish or 1350 ish for brief seconds on the screen and backdown is 100%. why is that? The outside temp is -35 celcius and I have it all coming in under hood aimed at the whistler. even at stock setting 0 the alarm goes off. Is it maybe my engine revving high during shifts? (auto 48re) the initial revving maybe spurts high egts briefly?
Old 01-29-2008, 09:20 PM
Billm2004's Avatar
mine was doing that at first too. all i did was, instead of using the screw and nut the pyro came with, i stuck a rivit in there, and all of a sudden my temps were in the normal range.
Old 01-29-2008, 09:30 PM
sallyman1's Avatar
lol. serioulsy. i wonder what is wrong? maybe its slippage?
Old 01-29-2008, 09:34 PM
sqrl$$'s Avatar
Had the same problem. Call edge, they will have you put a ohm meter on the pyro. Mine was reading the wrong resistance. They shipped me a new one and everything is great now.
Old 01-29-2008, 09:36 PM
sallyman1's Avatar
ok thanks. they r shipping me one to.
Old 01-29-2008, 10:02 PM
Billm2004's Avatar
No really, im dead serious! thats all i did and it was back to normal! no joke!
I just put a rivit where there pyro wires connect to the wires to my outlook instead of the screw and nut.
Old 01-30-2008, 12:07 AM
qzilla's Avatar
Maybe it is a Thermocouple problem........BUT
When is everyone with a 600 motor going to realize that 1300-1400 deg is normal and not hot???? That should be a sticky.
That and some boost pressure stickies for the 305 vs 325 trucks. Those questions must be asked at least once a day.
Old 01-30-2008, 01:25 AM
Kman9090's Avatar
I can't even see 1350 on my truck and look at my mods. I should be seeing alot more then that expecially when everybody else sees 1450 with just a chip.
Old 01-30-2008, 04:14 AM
Dodgezilla's Avatar
Your truck probably hit those temps even stock! Mine did... If I were you I would set the max EGTs to 1450 degrees......
Old 01-30-2008, 04:35 AM
preloader's Avatar
I never see above 800 degrees and pull a heavy RV all over the country.
Old 01-30-2008, 05:49 AM
sallyman1's Avatar
if i set mine to stock i see those egts. The other thing could be to is maybe I have GOOD compression. I am using winter diesel and power services additive.?
Old 01-30-2008, 06:56 AM
Minwy's Avatar
Your pyro is not reading correctly, I wouldnt trust it.
Edit, I see your post turbo, but that still sounds a little low compared to what most truck run. Last truck I drove with a setup like yours with the probe pre turbo would hit 1500 easily.
Old 01-30-2008, 07:55 AM
canadiandiesel's Avatar
you never see 800' because your pyro is post turbo, a pre turbo pyro should see about 1200 running empty when you step on it unless you are modded right up. i have only seen +1200 when pulling my trailer and step on it.
Old 01-30-2008, 10:03 AM
sleeperman's Avatar
I can go down the road running 600 and floor it and peg my 1500 egt gauge. So what do i do ?Turbo time!
Old 01-30-2008, 10:16 AM
kuhkuhkyle's Avatar
Look at the turbo youre running as well. that'll keep the egts in check quite abit.
Quick Reply: Why are my egts high?
