whole dash blinking?
Old 12-15-2008, 07:13 PM
Bbabic1's Avatar
when I start my truck on occasion the dash starts to blink bright then dim over and over for about 5 minutes then stops. anyone know what could cause this?
Old 12-15-2008, 07:17 PM
infidel's Avatar
Grid heaters cycling?
Is it doing it in time with your voltmeter jumping up and down?
Old 12-19-2008, 01:19 AM
Bbabic1's Avatar
it normally does it in the cold, and it either starts right when i turn on the truck or when i press on the breaks. the voltmeter isn't jumping.
Old 12-19-2008, 08:13 AM
nkennedy's Avatar
Sounds like bad connections, or low voltages. Could be due to Grid Heaters, but I see my volts drop when they cycle.
Old 12-19-2008, 08:38 AM
klx650a2's Avatar
When you first start the truck, that is normal, if it happens when you hit the brakes, that is bad. I would check with a voltmeter when you hit the brakes to see if the voltage/amps are dropping.
NoSparkplugs
17
05-17-2009 10:36 PM
slimpicken
01-02-2009 11:41 PM
CTD_Neil
12-09-2003 09:21 PM
MrBilly
08-17-2003 05:33 PM
mr4spd69
04-10-2003 11:22 AM
Quick Reply: whole dash blinking?
