View Full Version : White smoke........
97CTD
10-22-2002, 12:32 PM
I got some.....It is starting to get cold around here and i notice some white smoke and like a little sputter in the fueling if the truck is not warmed up completely is this normal? After it is warmed up the sputter goes away and from what i can tell the white smoke too (the exhaust comes out under the truck in front of the rear axle so cant see it that well). Is this fairly normal? I was reading in the FAQ about this and that is what brought it to my attention. I hope it isnt my injectors or anything as such what do you guys think?
Sounds like your timing needs adjusting.
Lary Ellis (Top)
10-22-2002, 12:36 PM
Pretty much a normal occurence in mine as well when it is cold. Soon as it begins to reach operating temp runs like a swiss watch in a bowling alley ;D
97CTD
10-22-2002, 12:53 PM
how much does it cost to have timing advanced or adjusted rather and where could i go to have this done do they do it at BMD?
97CTD
10-22-2002, 12:54 PM
<br>Pretty much a normal occurence in mine as well when it is cold. Soon as it begins to reach operating temp runs like a swiss watch in a bowling alley ;D<br><br><br>About how long does it usually take for yours to warm up?<br>
Lary Ellis (Top)
10-22-2002, 02:29 PM
<br><br>Pretty much a normal occurence in mine as well when it is cold. Soon as it begins to reach operating temp runs like a swiss watch in a bowling alley ;D<br><br><br>About how long does it usually take for yours to warm up?<br><br> Depends on how cold the temperature is but not very long as a rule. Mine will smooth out as soon as oil pressure is up and everything is pumping good( we are talking seconds here watching the gauges come up). The white smoke go's away in a mile or so unless I am hammering it, and I don't when it isn't at operating temp. All this is a non issue if I have had the heater plugged in, and I ususally do at anything near freezing. So we are talking about temps in the 40's to low 50's F that I even notice it.
97CTD
10-22-2002, 02:46 PM
oh ok then so obviouslyit isnt a huge ordeal i just bought the truckthis summer and never had it is semi cold weather and it jsut sorta worried me when i noticed this i hope that it is only cause it is gettin cold!!
Superduty12v
10-22-2002, 02:51 PM
Yeah. It's a diesel... a mechanically injected one at that... it's gonna smoke on cold days.
Lary Ellis (Top)
10-22-2002, 04:44 PM
Enjoy the ride It is just a tad coldblooded, shouldn't be a problem unless it continues well after it has had time to warm up.
DieselDaze
10-22-2002, 05:04 PM
A little bit of smoke is normal for a cold diesel.<br>If you want to cover all your bases, as CMNS_PWR said, check your timing. <br>Aslo, you may want to check all your fuel lines for any cracks/leaks. Especialy the fuel return lines.<br><br><br><br><br><br><br>Rich
<br>how much does it cost to have timing advanced or adjusted rather and where could i go to have this done do they do it at BMD?<br><br><br>I am not sure what Tom is charging to do timing, but they would be more than happy to set it for you. If you are gonna be at the dyno thing on the second, I am gonna try my best to be there. I can give them a hand if they need it when they time yours.
vBulletin® v3.6.7, Copyright ©2000-2010, Jelsoft Enterprises Ltd.
