Which Trans Line is it?
The hot trans line to put the trans temp sensor in; is it the one that goes from the trans to the heat exchanger, or is it the line that goes from the trans to the cooler and then the heat exchanger.
Also, if I end up putting the tee in, what did you use to cut the line with?
Cummins Guru
The front trans cooler line is the hot fluid to the ext cooler. Use a tubing cutter to cut line if installing a T for temp sensor.
isb07
11-18-2009 05:12 PM
Bradleysram
19
05-12-2009 08:36 AM
RoadDiesel
06-16-2007 09:24 PM
ckennedy
06-23-2006 08:21 PM
