PDA
View Full Version : which trans builder should I trust?
northslope
06-29-2005, 08:46 PM
Who should I go with for a built auto? I live in Southeast Alaska and nobody is just down the street, but DTT is the closest. I've seen alot of call Dave at Goerend's or call Bill at DTT give me some feedback on both can't make up my mind on who to go with. I like views on single and triple disc t/cons from both builders.
might be doing some competition in the future here's the list of bombs to come:
1) 191's
2) 370's
3) hx35/40 hybrid
I know this is a matter of opinion and I don't want to envoke a brand war but I highly value all of your opinions and experiences so tell me the pros and if any cons with both
Thanks in advance
halerazor
06-29-2005, 11:29 PM
what about sun coast or ats. i see those tranny's being used for pulling and dragging more than dtt or gorends
Got Smoke?
06-30-2005, 02:33 AM
You hear more, or see more advertising for those two brands pulling & dragging but I bet there are a lot more Goerends tranny's out there pulling and dragging than we know about. I hear plenty of DTT's out there, but don't hear many Goerends.
However after a ride in a '01 QC LB 4x4 with a Drag Comp & 40HP injectors sideways around a curve in the OPPOSITE lane I'm convinced and biased my next truck will have a Goerend Tranny!:o [laugh] :D
j-fox
06-30-2005, 06:16 AM
One by one, do a search on each brand.
You will quickly see who has the fewest problems and who has the most.
You are already looking at the two best.
PourinDiesel
06-30-2005, 07:16 AM
You might try checking out www.haisleymachine.com
They actually build pulling trannies and use parts from ATS, Goerand, and DTT.
Their trucks win truck pulls too!!
halerazor
06-30-2005, 11:53 PM
wich one of haisley's trucks has an auto. both there trucks are sticks and using at least a triple disc clutch
PourinDiesel
07-01-2005, 12:18 AM
Terry Coppess "BLUE GOOSE", Scott Amos, Chris Harness all of those are autos and are Haisley Machine trucks.
Terry was 10th place at this years THUNDER IN IRP in the street class.
He won last years Thunder in Muncie street class.
Chris Harness is #2 in the Sledpulling point standings in DHRA, Terry is not far behind in the top 10 in points.
FYI
John_P
07-01-2005, 07:34 AM
northslope:
FWIW, the Scott Bentz Diesel Rail Dragster has an ATS TripleLok Transmission in it.
You can call their toll free number (1-800-949-6002) to find a dealer near you.
John_P
northslope
07-01-2005, 09:29 PM
Originally posted by John_P
northslope:
John_P
My brother got....DIESEL? is an ATS dealer, but he has had a few mishaps with his trans & t/cons so his misfortune has led me away from the ATS way and more than likley towards DTT's direction just really being very discriminitive with whom I spend $4k with tryin to get feed back good and bad
PS it's gonna take a lot of overtime to afford a good one for me!![laugh]
king d
07-01-2005, 10:05 PM
i have a make shift tranny upgrade from a local shop transgo shift kit for the valve body,precision tq con and a 2nd drum with more frictions,seem to be holding well.if or rather when it goes il give tim barber and dtt a chance to price one ,if not il give joe at suncoast a call and get one of his
bama
07-02-2005, 09:34 PM
i say none of them..............buy you a old tranny,study all you can,and build it yourself.machining the drum,adding one clutch disc to the packs,and increasing line pressure isnt rocket science,and sure isnt worth 6 thousand dollars,,and you can take that to the bank.........................bama
04.5HO600
07-02-2005, 11:36 PM
Suncoast..wizards
GO 4LO
07-04-2005, 02:18 PM
Tried getting info from all the major trans builders, and Dave Goerend was the only one who took the time to get back with me, and on his own time at that. I'm going with Goerend on my '93...
Chris
JoshPeters
07-06-2005, 07:09 PM
I have a Goerends Tranny and one of his "Trick Tripple" converters. I have personally been to his shop and it is a top notch operation! They do ALL thier own converter work. The Stator in the converter I have has a patent on it. While I was there, Dave took the time to sit down and explain EXACTLY how the 2-3 shift works. Not by just telling us, but using parts that were sitting there and actually illustrated it. He's a busy guy..he could have just asked us to sit in the waiting area like most shops. He invited us into the shop and showed us anything and everything we wanted to know. He took the time because he actually cared about our Business. Not just making the bottom dollar.
He also explained to us how and why he has his transmissions shifting smoothly, and not harshly. There are 2 reasons.....Dave works on ALL trannys, but knows the Dodge's the best.
He had a local Ambulance come in needing a tranny. So he BUILT it to handle anything and everything. Well about 2 weeks later they brought it back in and said you HAVE to soften the shifts! He said it took quite a bit of work but he got it dialed in.
With the torque our engines provide everyone complains about breaking shafts at the shifts. Think about that.....Take a foot long extension, put it on a stuck bolt. LEAN into it....smoothly. You can make that extension flex a LONG ways before something pops. Now SLAM that thing around.....Either something is gonna give, or break. Same thing with the shafts in our transmissions. Make the Tranny shift smoothly, but hold the power...you now have the best of both worlds.
I have sled pulled 2 times with my truck. Neither time did I feel the truck upshift or downshift. I could hear it, but not feel it.
How about the warranty. Best in the Biz.
Try suncoast's warranty.....if they even have one anymore!
I had a Suncoast....send me a PM as to why I will tell EVERYONE to stay away from them!
my .02
Josh
doodah
07-06-2005, 09:32 PM
I agree with everything Josh says about Dave G. I am about 40 minutes away.and just got mine back from him. AWSOME!!! went with the triple lock, billit shafts, and billit plate, I went farther and also put new lines, and oversized cooler on also. definilty give dave a call today! you'll be glad you did!! shawn
bmoeller
07-06-2005, 09:51 PM
Chris
Talked to Dave for a couple of hours, before I bought mine. He was at home, too. Could hear the kids messing with piano in the background. LOL
For racing, I think you will need to spend more than $4k. The billet shafts are exensive. I think $4k will get you a Goerend tranny with the billet input shaft included. No other billet, though. I should've went ahead and had him install billet in mine, but didn't have the $$ for it at the time, and the tranny wasn't gonna allow me to wait. Slipping bad, even empty.
I don't think a 40/35 hybrid will be enough turbo. I can make plenty of heat with the PDR HX-40, and the 191s aren't in yet. Still sitting in the box, waiting for a socket.
mcoleman
07-15-2005, 11:54 AM
Haven't heard of anyone breaking shafts on a shift. Most if not all shaft breakage is done on the launch. I wouldn't even think of racing a truck and throwing a hard launch on it without a billet input and output shaft regardless of who built the tranny. The intermediate is a pretty hefty piece and will handle normal 20 -25 psi launches. My stock output broke on an easy 10 psi launch. I've went as quick as a 1.66 60 foot time on the billet output.
1dslram
07-16-2005, 08:19 PM
I broke the imput shaft on the 2-3 shift, at the Truckin for kids meet in Lancaster, CA 2 years ago, this was after a local shop modified the valve body. I replaced the valve body with a new ATS unit and a HD imput shaft installed. Then the flexplate let go, I had a SFI certified flex plate installed, after that I lunched the hardened imput, convertor and front drum. ATS covered it all under warranty with a small deductable for the $3,000.00 in parts. ATS and Bellflower transmission have been more than fair with me when upgrading or replacing broken parts that were no fault of theirs.
Bruce
justinp20012500
07-24-2005, 02:05 PM
I broke an input shaft on a 1-2 shift with the TC engaged after the shift.
You break output shafts doing stall tests or high boost launches at the track.
I would much rather break an output then an input hands down!!!! Much easier to change. When the input goes it usually takes out the pump and possibly the TC.
Justin
