Which tires?
Old 05-28-2008, 09:09 AM
Garrett's Avatar
Which tires?
Pleased to say that I've got 60,000 miles out of the original tires on my 2005 Dodge Ram 2500 (265 70 R17).
90% of my time is spent on the pavement in Southern California with an empty load. The other 10% of the time, I'm towing an 8,000# travel trailer.
I was thinking about putting a leveling kit on the truck and going to 285s. Is that advisable?
What's a long-lasting tire that I can tow with, but still be comfortable with driving around empty?
I was thinking BF Goodrich Rugged Trail or All-Terrains.
Any thoughts?
Old 05-28-2008, 09:35 AM
SundayMoney's Avatar
Alot of guys will tell you that all that matters is the load capacity of the tires. They'll say that a D rated 285 will carry the same load as an E rated 265. Thats all well and fine,but IMO tire construction is also important. A D rated tire is a lighter duty tire than an E.
A 285 will be fine (thats what I run) but I won't run a D rated 285. I'll only run an E rated 285. The problem is,there isn't a ton of choices in an E rated 285.
I have Nitto Terra Grapplers. They look good,have excellent traction in wet/snow (not a concern for you),but just don't last long.
Nitto has a new line called the Dura Grappler,which sounds like its exactly what you're looking for. Its more aggresive than a "street" tire,but not as aggresive as an all terrain like a BFG or Terra Grappler.
Personally,I think leveling kits look terrible. I haven't seen one yet that was actually "level". They all have that broken down rear suspension look,where the rear is lower than the front. Towing with a leveling kit only makes it worse. The rake the manufacturers give a truck is for a reason,when you put a load in the truck it will ride level.
The 285s will fit fine without a leveling kit.
whosdunit
03-12-2010 09:38 AM
1320
05-29-2009 10:24 PM
Bradleysram
19
05-12-2009 08:36 AM
sakisaki400
23
12-31-2006 10:17 PM
Captain
09-09-2005 12:16 AM
Quick Reply: Which tires?
