View Poll Results: which Smarty SW to run for Diesel thunder?
Smarty Wild, aftermarket turbo, stock inj with quad race
6.25%
Beta 4.1
0
0%
4.2
25.00%
4.3
12.50%
4.4
56.25%
Voters: 16. You may not vote on this poll
Which Smarty program to Run
Old Aug 6, 2007 | 05:02 PM
dodgezilla04's Avatar
Which one should I run for Diesel Thunder this saturday?
loaded is the aftermarket turbo, stock injectors, wild TQ Man. stacking with the quad race.
So, run with that, or load Beta 4.1,4.2,4.3,or 4.4?
dyno'd at christmas with same smarty program on 8, and quad cranked up. Recent mods have been CP3 mod and headstuds. Previous runs had boost set at 42 because of lack of studs. Not a problem now.
Old Aug 6, 2007 | 05:05 PM
haloman's Avatar
Does your quad have timing? I would say right at 50ish pounds of boost. Which program runs the hardest on the street for you?
Old Aug 6, 2007 | 05:08 PM
well beta 4.2 stacked with my quad ran hard enough to pop a freeze plug, dont want to try that again.. gonna set the boost around 50ish
quad has timing, pressure, and duration.
smarty will be even number if stacked.
Old Aug 6, 2007 | 05:13 PM
haloman's Avatar
Gotcha. Have you tried running that previous program with the higher boost levels? I would say whatever gets you to your wastegate the fastest without overpowering it. Ah shoot run the most powerful beta on 8. what can it hurt. :X LOL
HTH's
Daniel
Old Aug 8, 2007 | 11:29 AM
just got off the phone with bob. gonna run beta 4.2, stacked with quad race, and boost set to 50psi. that'll be fun....
Old Aug 8, 2007 | 11:32 AM
RyeThomas's Avatar
Winner winner chicken dinner!
I agree, I run 4.2 everyday and it pulls. Watch the freeze plugs though.
Old Aug 8, 2007 | 11:54 AM
already popped my freeze plug on 4.2, the first 5 minutes i ran it. havent loaded it since. you pop one rye? i plated the rear one and nipped one of the barbells on the tstat. hopefully that's enough
Old Aug 8, 2007 | 11:56 AM
haloman's Avatar
DZ04, you have a BOE kit installed right?
soulezoo's Avatar
DTR 1st Sergeant
OK-- I have to ask...
I have beta 4.3 and 4.4 and run the 4.4 everyday.
So can you explain why Bob recommended the 4.2? What is the difference with the 4.2 opposed to the other two?
Old Aug 8, 2007 | 11:59 AM
daniel, no boe kit, never received word that it is available, mike's a busy guy.
soule, 4.3 and .4 add pressure, 4.2 just ramps the pressure up earlier, cant safely stack .3 and .4 with a quad that adds pressure too.
Old Aug 8, 2007 | 12:02 PM
haloman's Avatar
I see, the plate "should" hold all you can throw at it right?
Old Aug 8, 2007 | 12:04 PM
soulezoo's Avatar
DTR 1st Sergeant
DZ04-- gotcha-- Thanks!
Old Aug 8, 2007 | 12:07 PM
that plate only takes care of the one it is blocking, what about the other pile of them?
Old Aug 8, 2007 | 12:08 PM
i think that rye is busting my chops becuase i blew the plug the night before the bd dyno day in may while testing the 4.2 . i believe that i let her have it before i was fully warmed up.
i havent heard of anyone popping one since. hopefully he is just giving me grief.
Old Aug 8, 2007 | 12:11 PM
haloman's Avatar
Gotcha, learn something new everyday. Beta 4.2 and quad race sounds good.
