Which programmer for RV towing ????
Old 12-01-2008, 04:10 PM
TRASHMAN's Avatar
I want a little more performance esp when towing the 30 ft 5th . got 285s on the ground and the truck is bone stock .You guys that have been there tell what you recommend i want to keep her dependable just looking for around 50 more ponies
Old 12-01-2008, 04:19 PM
STATELINE's Avatar
I'm interested in this also. I really liked the way the Bully Dog power pup set on tow worked on my 05, looking for something similar to that for an 01
Old 12-01-2008, 05:22 PM
WestTN's Avatar
Smarty on fuel saver setting does a great job. However, you will need to monitor that automatic trans closely. You might also need a boost fooler elbow to get the pressure. I don't know if you have a wastgate or not.
Old 12-01-2008, 10:13 PM
Wild4kst8's Avatar
my first was a powerpuck... it was OK but didn't notice much while towing...
recently got a smarty & had it on #3... OMG, i only towed my trailer to storage, but, holy cow what a difference... i currently have the smarty set to #4 & stacked w/powerpuck & it is unreal empty... i won't being going higher until i have further upgrades... can't wait to pull the trailer again... BTW, the smarty has bumped up my empty MPG 1.5-2.0
Old 12-03-2008, 08:19 PM
ILIANBG's Avatar
Does the smarty have a built-in boost fooler function? I am also thinking about smarty.
Ilian
Old 12-04-2008, 10:41 AM
Wild4kst8's Avatar
Ilian
it has boost, fuel, & timing... if you go to madselectronics.com, they have plenty of info
Old 12-04-2008, 11:16 AM
98whitelightnin's Avatar
Quadzilla xzt+ is 65hp, usb updatable, has boost fooling, and adds timing and fuel. I have one and it is a good little box.
Old 12-05-2008, 05:36 PM
ironbutt's Avatar
Your truck info doesn't say what gears you have, nor do you state what weight trailer you are towing. If you have 4:10 gears , all you need is a mild bump in HP. (like a edge or a power puck) If you have 3:54 gears , with those taller tires you should think of beefing up your auto before you strain it too much. A more powerfull fueling box will be nice , but for towing you need just a little more torque. ( just my $.02)
Old 12-06-2008, 07:47 AM
high bid's Avatar
x2 on the XZT+. A great versatile box w/tons of different software applications avail for download to fit your needs. Don't get me wrong, a Smarty is great but the XZT+ is priced at about half the cost. JMO.
Old 12-06-2008, 08:54 AM
nickg's Avatar
I was in the same boat as you.. and went with an edgeEZ then got gauges and a pillar pod, time I was all said and done I spent 700+ (Canadian prices) It made a huge difference in towing, and everyday driving, Then I went with Edge juice/Attitude, it comes with a monitor and the ability to set warnings (alarm if you exceed things like EGT/ fuel pressure etc) It gives 120hp if you tap the VP or just 60hp(same as an EZ) if you dont, trust me dont waste your hard earned money buying things twice. The Edge J/A cost almost the same as what I spent on a 60hp box and mechanical gauges,and you get so much more with a better box. unless you get the stuff used you might as well buy the better box from the get go. Quad makes good stuff to, but I've never used it, and can only speak for what I've used.
Here is a link
http://www.edgeproducts.com/product.php?pk=52&pvk=142
good luck with your decision
Old 12-06-2008, 03:10 PM
wyomingcowboy's Avatar
I'm looking awfully hard at that edge juice and attitude. My only concern is too much power. I don't want to rebuild trannies and upgrade clutches nor do I want a bigger turbo, blah, blah, blah. A nice 4" exhaust and my stock clutch and NV5600. Is the Juice gonna be too much for me?
Old 12-07-2008, 11:39 AM
jiMMyCTD's Avatar
i have the edge drag comp, does it do any timing???? i know towing through the hills i have to have it on 1 or off. flats i can have it on 1-2. this is with a 30ft toy hauler loaded at 13k give or take... just curious on the timing. also im going to drop from 315's to 285's.
Old 12-07-2008, 09:21 PM
nickg's Avatar
the beauty is if you dont tap the wire you ONLY get 60hp, same as edge EZ, and you still get all the advantages of eng protection and gauges......the only way it's too much power is if you tap the pump wire
Old 12-07-2008, 09:29 PM
91rangerturbo's Avatar
I have a edge juice with attitude for sale that fit's a 2001 and 2002 year trucks. If anyone is looking for one. It's a great box and only nets 60hp without the wire tap and it is a complete package gauges, turbo timer, fuel pressure, transmission temp and more....
Here is a details and pricing from edge's website.
I have one for sale here practically brand new.
https://www.dieseltruckresource.com/...ct/22887/cat/8
Old 12-07-2008, 09:31 PM
Even if you do tap the pump you can always just turn the box down, if your not gonna tap the pump you might as well just get the EZ or something similar and save your money.
Quick Reply: Which programmer for RV towing ????
