Which injector size best for towing?
Old 07-01-2007, 05:25 PM
Jordan5687's Avatar
Question Which injector size best for towing?
I'm looking at the Edge Jammer injectors and was wondering what hp size should I be looking for in an injector? What's the max hp size I could tow with? Any other injectors I should look at that are good quality? I haul a lot with this truck, so not really looking for race injectors or anything real extreme. Thanks for the help.
Old 07-01-2007, 08:03 PM
HOHN's Avatar
Best injector size for towing safety is stock. Best for towing power is a 200hp race injector. Obviously, you can't have both.
Jammers are decent, but look also a the Mach injectors and the DDP sticks. Keep it under 75hp to tow reasonably safely with the stock turbo.
jh
Old 07-01-2007, 09:19 PM
24valvepuller's Avatar
I used to tow with 125 hp injectors and an hx-40 and it was awesome until I hit 4th gear and I couldn't see the pyrometer needle anymore. I had to glance at the road and stare at the pyro. One time I had a set of stock injectors in with a Van Aaken timing box and a hot torque enhancer and it was the easiest towing I have ever done. Flat ground grossing about 25k I would turn the hot box off and I would never even have to look at the pyro, hit a hill turn the fuel back on and it still wouldn't hit 1250 That was the last time I towed with my VP and if I do it again I would have stock injectors and a decent box, I would stay with what you have now
Old 07-01-2007, 09:30 PM
Jordan5687's Avatar
I'll keep all that into consideration, not looking at installing them until I've got a rebuilt tranny and a different turbo. Or at least the money for another turbo.
Old 07-02-2007, 02:10 AM
HOHN's Avatar
A different turbo will change everything. The turbo you choose will determine if you can tow with a 40hp injector or a 150hp injector.
Match the injectors to the turbo.
Justin
Old 07-02-2007, 10:56 AM
Jordan5687's Avatar
Ok, should I also get my truck dynoed before deciding a turbo as well? Are the turbos chosen by the hp output? Cause when I get one, I'm gonna be clueless as to which one to get.
Old 07-02-2007, 11:21 AM
RowJ's Avatar
Don't need the dyno... but it's good info and they are fun! Come on down to Alvarado, Tx on the 14th!
If towing over 7-8,000 lbs, I would stay around 100 hp injectors. Best I've seen for less smoke and lower egt's when towing are Mach 1.6's. Jammers will work ok.
With your auto (?) I would recommend a PS 62/12 with 100+/- hp injectors.
http://www.industrialinjection.com/id41.html
http://www.f1diesel.com/injectors24.html
RJ
Old 07-02-2007, 11:51 AM
dodgediesel's Avatar
Which mach injectors work well with a HTT 62/13 SS and HRVP. Are Mach 4's close to 80 hp Jammer's egt wise???
Old 07-02-2007, 12:33 PM
RowJ's Avatar
Originally Posted by dodgediesel
....Are Mach 4's close to 80 hp Jammer's egt wise???
I would not say F-1 injectors are THAT much cooler running..
They do, however, run an average of 50-75* cooler that others of the same hp... from my experience with the older DD'2 and Mach 2's.
RJ
Old 07-02-2007, 04:05 PM
Jordan5687's Avatar
Well, sounds good! I'll try to be there, depending on work schedule. I won't enter anything with my truck though, maybe next time.
The_Head
02-21-2011 08:22 PM
schoust
10-21-2009 10:09 AM
Bradleysram
19
05-12-2009 08:36 AM
Gorth
02-09-2008 09:02 PM
jdeereboy
09-10-2004 02:01 PM
Quick Reply: Which injector size best for towing?
