Which diff
Old Jul 25, 2006 | 01:52 PM
Fergavs's Avatar
Which diff
Hey Guys,
I am ordering a locker for my 89 Dodge D350 2wd Duallie Reg Cab and I am not sure which diff it has. I was told it could be a D70 or A D80 but I also read that dodge used slightly modified Dana axels. I don't want any miss ordered parts so if anyone knows which it should be please let me know. Thanx.
Old Jul 25, 2006 | 02:07 PM
bgilbert's Avatar
Either a Dana 71 if you have an auto or a Dana 70 if you have a 5 speed.
Old Jul 25, 2006 | 04:59 PM
pred's Avatar
I hope that you are getting a selectable locker, or a limited slip
If you go with a detroit you wont be happy!
Peter.
Old Jul 25, 2006 | 05:20 PM
xtremexj's Avatar
Peter.
Why? Because they are so hard on parts? If I wouldn't have listened to people about the 'problems' with Detroit Lockers I would have been happier. Nothing wrong with them if you know how to drive with them.
Old Jul 25, 2006 | 09:11 PM
BigWaylon's Avatar
are there any other possible options, like the D80?
I needed to change a rear axle seal, and the "parts computer" gave two options for an '89 D350...a D60 and a D70...so I bought two of each, and when I got the busted one out, it was bigger than both of the ones I bought at the store...
the computer never asked for SRW or DRW...would that make a difference?
Thanks.
Greg
Old Jul 26, 2006 | 10:52 AM
Fergavs's Avatar
I will not be using a selectable locker. I love going sideways! It is was of the funest things you can do in a vehical. However I will be towing in snow and possibly mountain areas so that will get a little hairy. I currently own a old dodge gasser with a loc rite in the rear and it has been rock solid through many burn outs,its ratcheting is not very loud and it works well. I also use one in the front of my 79 bronco 4wd and although I have broke A LOT of front end parts my loc rite has never let me down. so I will be installing one in the rear of my duallie.
Old Jul 26, 2006 | 12:34 PM
bgilbert's Avatar
If auto, I don't think a locker is available for for the D71.
Old Jul 26, 2006 | 02:14 PM
Redleg's Avatar
If you have an auto, whatever you chose is gonna require machineing. The only other option is to get a used one out of a like truck or find one in a dealer wherehouse somewhere for that year auto, diesel. I don't know if they actually offered them in the auto though. If you HAVE to have a locker, it'll be easier just to swap an axle since it is only 2WD. You could probabl recoup some of the cost eventually, to someone with a 4x4 that could use a rear end. If you haven't guessed yet, 89-91 auto's came with a 3:07 gear. Nothing for it is available anymore and parts are not interchangeable with the other gears.
Old Jul 26, 2006 | 04:03 PM
pred's Avatar
Please dont get me wrong, I love the detroit, I have one in my discovery, It is great,,, I have some expirence with a locker in a rear wheel drive truck,,, besides the noise, and the chirping of the tires, I am looking at it from a traction point of view,,,, with a limited slip, or better yet, a selectable locker you have a choise of going sideways or not, I have been on some scetchy mt roads in the snow with the detroit and a selectable, and for my tastes, i'de rather spin one wheel and stay straight, than to spin two and slip torward a 200' fall,,, no guard rail,, Then i needed to pull out the winch,,, The only way i could get up the hill was to run the rear tires at 8 lb,,, I would like to see the new detroit cable locker,,,
Just my opinion
Peter.
Old Aug 2, 2006 | 11:25 AM
Fergavs's Avatar
Pred,
Good point. Kinda throws things into perspective with the whole 200' drop mountain road thing. Thanks for everyones opinions.
My truck is a stick shift so that should save some headache.
An 89 w/ stick in a duallie should be a Dana 70?
Old Aug 2, 2006 | 12:45 PM
Begle1's Avatar
Don't tell me that... You mean that I can't get a locker of any kind for my truck? Darnnit! Wouldn't be so bad if anything else was this heavy of an axle and this short of gears...
Old Aug 2, 2006 | 01:40 PM
flashgordon's Avatar
Maybe a lock right! thay just req removing the spider gears on a open diff and puting the lock right in it's place!
not as strong as a detroit locker but, it would stlll work!
Old Aug 2, 2006 | 03:53 PM
Yes, it is a Dana 70.
afate45
Jun 7, 2014 12:08 AM
banana
Dec 1, 2009 11:44 PM
Bradleysram
19
May 12, 2009 08:36 AM
223 rules
May 4, 2007 07:58 PM
dbunhook
15
Feb 24, 2007 05:47 PM
