which cooler line is the hot line on a 48re
Old 11-14-2009, 04:10 PM
isb07's Avatar
hey all im wondering which line is the hot line coming out of the 48re? i had a temp gauge installed on my truck by a local shop and they put it in the rear line. Is that right i thought the front line is the hot line?
Old 11-14-2009, 05:03 PM
no_6_oh_no's Avatar
Front line is the hot line, rear line is the return line.
Old 11-14-2009, 05:38 PM
isb07's Avatar
thanks im going to have to Edit to the local shop they told me they put it in the hot line coming out of the tc
Old 11-18-2009, 12:49 AM
Big Red Ram's Avatar
They cross. Look again. Is it the front line COMING OUT or the front vertical line? I looked and looked... I put my "true temp" on the rear VERTICAL. I will have to double check tomorrow, but all the "replacement" lines looked like the one I attached to...
I believe that it is the rear VERTICAL line.
Old 11-18-2009, 08:21 AM
KWKING's Avatar
Maybe this will help, got it from Diesel Manors instruction sheets under support.At the point of the arrow it is the rear line,but maybe they cross above ,it is not too clear in the photo.But you can see where they installed the tee.
Attached Thumbnails which cooler line is the hot line on a 48re-gen3coolerline1-lg.jpg
Old 11-18-2009, 09:17 AM
ratsun's Avatar
Best way to tell if your unsure is start the truck when cold and feel the lines.
Have someone you trust hold the brake and block the wheels with the ebrake on and put the truck in drive will show quicker results.
Old 11-18-2009, 01:18 PM
isb07's Avatar
its the front line coming out of the trans, just swapped them and now my temp are about 30-40 degrees higher
Old 11-18-2009, 05:12 PM
KWKING's Avatar
You could also check line temp. if you had an infrared temp probe.Best way is to probably just do a slight warm up drive and check by hand as said above.
whosdunit
02-16-2019 04:07 PM
Strjock81
16
12-12-2007 09:53 AM
edwinsmith
04-14-2006 03:53 PM
duallydave
08-07-2005 09:38 PM
Quick Reply: which cooler line is the hot line on a 48re
