Which coolant can we use??
Old 10-05-2006, 10:21 PM
OR4ster's Avatar
My coolant is low, so I looked up the recommended fluid in the owner's manual. What is HOAT (Hybrid Organic Additive Technology)?? I looked at the store and I see Prestone's "All Model, All Makes" and GM's special stuff. Is there something relatively inexpensive that works in our CTDs?
Old 10-05-2006, 11:20 PM
doorguy's Avatar
Hoat is orange pinkish color and nonhoat is green in color. Do not mix the two, they have different PH levels and it could possibly cause a corrosive reaction.Look and see what color you have and stick with it. It is more and likely orange so buy a jug of long life diesel antifreeze, if its green get a jug of green diesel antifreeze.
Old 10-06-2006, 05:56 AM
SupaDupa's Avatar
I used Zerex in the gold plastic bottle. It's HOAT. It's pricey though; you'd think the bottle was made of gold!!
Old 10-06-2006, 09:07 AM
jkitterman's Avatar
Zerex G-05 is HOAT. You can use Ford Gold coolant or get it from DC. Color is not standardized to the coolant type so don't go by that. Why the coolant loss?
Old 10-06-2006, 10:36 AM
Jnoble's Avatar
I'm planning on changing mine this week. Going to replace the Dodge stuff with the Cat ELC.
Old 10-07-2006, 01:09 PM
pooperscooper's Avatar
You can use either, just dont mix. Either being the HOAT or Just the Plain Jane green stuff. wont hurt anything in anyway.
Old 10-07-2006, 01:22 PM
John Halter's Avatar
Location: somewhere in northwestern ohio....Mansfield, Oh
As long as it is in a Dodge any color is good on the Fords you need the high buck stuff , about 18.00 a gallon . With winter coming I was doing the same thing today , drained the 7.3 and put new in and check all the tractors , cars and trucks , let it snow . I don't know what a Duramax takes , is it a wet liner are dry ?
Old 10-07-2006, 01:38 PM
B.Law's Avatar
I'm way overdue for a flush, how many gallons does our trucks hold? I may try to find some pre-mixed gallons of HOAT just to simplify...
Old 10-07-2006, 03:34 PM
Hemi Dart's Avatar
I like to use "Holy Water" to cut the undiluted coolant.
Totallyrad
07-19-2011 07:41 AM
Bradleysram
19
05-12-2009 08:36 AM
bigragu
03-19-2006 03:52 PM
GBPB
05-10-2005 08:16 PM
cmckinney
15
02-19-2004 04:47 PM
Quick Reply: Which coolant can we use??
