Which Ball Joints?
Old 05-20-2008, 03:42 PM
Knuckle Head's Avatar
Question Which Ball Joints?
SPICER Part # 6154008 {Professional Grade}
Front Suspension; Upper; Four Wheel Drive (4X4); Plus Or Minus 1 Degree Camber; Offset Ball Joint Replaces OEM To Provide 1 Degree Positive(+) Or Negative(-) Camber/Caster Change
or
SPICER Part # 6154009 {Professional Grade}
Front Suspension; Upper; Four Wheel Drive (4X4); Plus Or Minus 1-1/2 Degree Camber; Offset Ball Joint Replaces OEM To Provide 1-1/2 Degree Positive(+) Or Negative(-) Camber/Caster Change
Not sure about the Camber degree?
Info taken off of rock auto web site.
I got one that is popping and making all kinds of noise!
thanks
Old 05-21-2008, 01:07 PM
Aggie007's Avatar
Since you have a little bit of lift I would go with the one with the more camber off-set.
firebill1720
20
03-05-2010 09:23 AM
njmaier
15
07-26-2006 07:43 AM
getblown5.9
05-02-2006 10:01 PM
Seeder
02-15-2006 08:15 PM
Dynocon
03-05-2005 06:24 PM
Quick Reply: Which Ball Joints?
