wheels
Old Aug 1, 2009 | 04:46 PM
comptz's Avatar
wheels
will the rims from a 2003 dodge cummins 2500 go on a first gen 250? and what about the other way around. Thanks
Old Aug 1, 2009 | 04:56 PM
jesussaves's Avatar
they both have the same lug pattern
Old Aug 1, 2009 | 05:00 PM
comptz's Avatar
what about backspacing and all? Will i have any problems with rubbing or not fitting?
Old Aug 1, 2009 | 05:38 PM
jesussaves's Avatar
no since your is a 4wd you should be good to go, i have a 2wd so i had to get a 1.5" wheel adapter to clear the front suspension components and bigger bulge lugnuts
Old Aug 1, 2009 | 05:41 PM
comptz's Avatar
Thank you.
Old Aug 1, 2009 | 05:46 PM
jesussaves's Avatar
some people replace all the studs b/c the newer dodges have 9/16 studs and lugnuts but you can just get larger 1/2 lugnuts for our 1gen studs like
http://cgi.ebay.com/ebaymotors/32-LU...Q5fAccessories
Old Aug 1, 2009 | 05:48 PM
comptz's Avatar
ok, should i have a problem putting the wheels on the first gen since the studs are not as big as the third gen or should the rims be good?
Old Aug 1, 2009 | 05:52 PM
jesussaves's Avatar
no the lug nut will make up the size difference i dont know for sure about placing 1gen wheels on a 3rd gen though/
Old Aug 1, 2009 | 05:56 PM
comptz's Avatar
The wheels on the first gen are american racing wheels so i don't know about the bolt holes.
Old Aug 1, 2009 | 06:00 PM
jesussaves's Avatar
im sure they will work most wheels have a tapered lug nut hole so you can use them on various vehicles with different stud sizes. If you did want to switch out all your studs their is info on how to do it in the 1 gen sticky FAQ section
Old Aug 1, 2009 | 06:02 PM
comptz's Avatar
Old Aug 2, 2009 | 11:20 AM
schamran's Avatar
You will need spacers! I put 1.5" spacers on. The ones I bought had 9/16 lugs in them instead of 1/2". That way i could use the stock 3rd gen nuts, and use the hub caps. i cut holes in the caps for the lockouts and they look real sharp. Check my profile out for pics!
Old Aug 2, 2009 | 11:51 AM
schamran's Avatar
ok, for whatever reason my profile doesn't have my pics....
Here...
Old Aug 2, 2009 | 12:06 PM
jimbo486's Avatar
very nice, clean truck!! i like the location of the lights on the bumper.
Old Oct 22, 2009 | 06:53 PM
blackfordd's Avatar
I'm diggin those rims. Where might Ia guy find those? Schamran, I PM'd you today about your rims. I see now you used 1.5" spacers. I just need to get put on a location for the rims.
David
