Wheel/rim weight capcity questions????
Old 03-09-2008, 07:44 PM
dieselcarpenter's Avatar
Question Wheel/rim weight capcity questions????
I am considering some low cost black steel rims for my truck. The version I want has a max load rating of 2000 lbs. My truck weighs darn near 7000 (I think, 6800 or something) That means a load capacity (people,fuel, cargo) of 1000 lbs or less is all she can handle by the book. Some of the alloys I have looked at are better with around 3400 lbs of max load. What should I do?
I want to tow/haul, off-road, and street/highway driving, maybe even sled pull or drag.
I am at a loss. I like the steels for the cost and all-black look, similar alloys are double the cost, what do I do? Plus I like a steel wheels ability to be hammered back when bent when alloys crack.
When you guys buy a rim do you pay attention to the weight capacity? Is there a specific capacity to look for?
http://www.4wheelparts.com/PDT63898.aspx
Old 03-09-2008, 08:36 PM
RAMRODD's Avatar
I got my 22.5 rims for the extra load capacity
Seriously, rims with a 2,000 load capacity would be dangerous with any kind of load.
Old 03-09-2008, 08:55 PM
Equalizer 2's Avatar
As you are driving a 91.5 model can you use the 16 inch wheels from earlier Fords? I see where all the 17 inch wheels are quite expensive and the one set of steel wheels I saw only have the same 2000 lb load rating. There are 16 inch Ford wheels through 91 that have a load rating of 3750.
See if you can find something to fit here; http://www.southwestwheel.com/
esorensen
11-14-2012 09:44 PM
johnr9q
06-04-2010 12:54 PM
jesussaves
12-12-2009 03:18 PM
Vintage Empire
01-12-2009 04:17 PM
acook
09-29-2006 02:44 PM
Quick Reply: Wheel/rim weight capcity questions????
