""wheel bearing seals""
Old 07-24-2011, 07:38 PM
whosdunit's Avatar
I went straight to the sticky to do the ball joints ( up& lower), replaced bad wheel bearings inner & outer, but the inner seals were turned over from the ones in the sticky----have i also been putting them in wrong???? The groove faces out?????
7 out
Old 07-24-2011, 07:51 PM
maybe368's Avatar
Originally Posted by whosdunit
I went straight to the sticky to do the ball joints ( up& lower), replaced bad wheel bearings inner & outer, but the inner seals were turned over from the ones in the sticky----have i also been putting them in wrong???? The groove faces out?????7 out
The lips, with the spring, go towards the bearing. Did you replace the bearing cones also?..Mark
Old 07-24-2011, 08:38 PM
whosdunit's Avatar
Yea, mark who ever did the job before me didn't have hardly any grease on them , the spindel was dry & rusty . I replaced both races & bearings, now i;v got to do the the other side& the ball joints just to be sure( it's always somthing when you follow someone elses work).Thanks your answer means i put my seals in right,
Old 07-24-2011, 10:43 PM
BearKiller's Avatar
Like he said, the lips with the spring face the bearing.
I have seen people install them backwards.
I like the much better version on my Ford Dana-70; it has a lot more meat and a big flange that seats against the perimeter of the hub.
With care, I can even coax one of those out to inspect the bearing/race and not damage it.
I can't ever remember to check the compatibility on a Dodge Dana-70.
I like to fill that spring lip cavity with Kendall L-427 Super-Blu.
silverbullet02
10-05-2009 12:16 PM
Wilbur01
08-03-2009 11:16 PM
wadecool
01-12-2007 11:39 AM
Joseph H. Smith
16
01-06-2007 08:13 PM
Quick Reply: ""wheel bearing seals""
