Wheel backspacing problem
Old 08-18-2005, 06:34 PM
WV-Diesel's Avatar
Ran into a problem today. I bought some wheels and tires 16" off of a 2001 dodge thinking they would fit my 96. They don't clear in the rear they hit the drum! Is the backspacing different from the 96 to 01? I thought maybe a could get some wheelspacers, but is that a good idea? I was just trying to figure something out because I don't know if the guy will give me my money back. Any ideas would be great. Thanks, John
Old 08-18-2005, 06:45 PM
2500Ram's Avatar
What truck do you have 3/4, 1 ton, any hauling or towing. I wouldn't recommend spacers if your doing any hauling or towing.
Old 08-18-2005, 07:59 PM
WV-Diesel's Avatar
3/4 ton, light towing if any.
Old 08-19-2005, 09:24 AM
infidel's Avatar
I've read a little about this problem that people have run into but haven't paid much attention but it seems that a lot of folks have been able to make new rims fit on old rigs with a little bit of grinding. Don't ask me where to grind though, maybe search for rims will answer your question
Old 08-19-2005, 10:01 AM
mkubacak's Avatar
I too have read about this one before. I believe you need to do some grinding on the brake drums. Like infidel said, a search will locate the answers.
Old 08-19-2005, 03:22 PM
JKM
JKM's Avatar
The newer trucks have different drums which allow the wheels to fit. you may be able to make them fit with some grinding , i have never heard of that before.
Old 08-19-2005, 04:05 PM
hotmopr's Avatar
You need to remove about an 1/8th from the outer drum lip. I have heard you can have it turned on a brake lathe or grind it. I believe the easiest wat to grind is to put the truck up on stands and put it in gear and let the drum spin while grinding. Grind a little and test fit. Thats what I have heard anyways.. Good luck
Redneck-Express
05-01-2009 12:45 PM
Ramtough
09-02-2005 01:04 AM
Hondo
01-09-2005 09:31 AM
Patrick Campbell
09-28-2003 11:03 AM
tobyw
06-06-2003 01:03 AM
Quick Reply: Wheel backspacing problem
