Whats wrong with my 4wd system??
Old 06-11-2011, 08:11 AM
schoust's Avatar
Ok Guy's not sure exactly what's up with my 07 but I am going to through it out there like I have done in the past and see what you all say. I was cleaning up my yard yesterday after a big storm and decided that I would try to finish off a tree that had fallen but was still attached. I proceeded to wrap the chain around the tree and pull the thing free. I put the truck in 4wd low and attempted a pull. Well I lost traction almost immediately?? In fact the front driver side wheel did not turn at all?? Do I have an issue or is this the way this diff work's?
Old 06-11-2011, 10:52 AM
darkvader's Avatar
front differentials are open. wheel with least traction spins other does not tirn
Clark
Old 06-11-2011, 04:01 PM
gcssr's Avatar
try applying brakes, easy, it stops the free wheeling, putting equal pressure at both wheels.
Old 06-11-2011, 05:27 PM
DTR Detective
steelblitzkrieg's Avatar
What gcssr said. Apply slight brake. The maximum torque produced is limited by the wheel easiest to slip.
Old 06-11-2011, 06:17 PM
TJAR66's Avatar
Careful with that chain I have a dent that looks lust like a broken chain link in my garage door from doing that exact same thing.
Old 06-11-2011, 09:36 PM
schoust's Avatar
Yea I was thinking about the possibilities of that whiplashing chain the whole time!
Old 06-11-2011, 10:04 PM
Adaminak's Avatar
Agree; pulling anything with a metal conveyance has the potential to go bad, but I will say that every time I've broken a chain, it just dropped to the ground. Of course, I'm not getting a running start if I'm stuck using a chain, and that probably makes a big difference. Steel cable, on the other hand, becomes a nice bullwhip that will cut through a LOT of things you'd rather not think of. IMO a blanket is mandatory if using cable.
Old 06-12-2011, 01:09 PM
TJAR66's Avatar
With mine the chain did drop but the busted link didn't. Sounded like a gun going off when it hit the garage. I picked up a strap that same day and used it to pull the stump. The chain is in a bucket in the garage
Old 06-12-2011, 03:26 PM
Hodge's Avatar
Back to your original question, it doesn't sound like anything is wrong- it is the natural order of how things work. Without lockers or real good limited slips, a 2wd is a 1wd, effectively, and a 4wd is a 2wd. It has to be that way, or it would be undrivable on pavement, and you would tear up the driveline.
Old 06-12-2011, 08:09 PM
rootkit's Avatar
you mean... 4wd is a 3wd =p
need lockers and free spining hubs and a eloc like the power wagons.
As for traction also helps to have the right tires for the job
93Fury
03-31-2010 01:33 PM
wrangler04
07-17-2007 11:00 PM
VikingDiesel
Competition / Pulls / OffRoad
12-29-2006 07:17 PM
95black2615
12-20-2006 06:37 PM
1320
05-06-2003 06:30 PM
Quick Reply: Whats wrong with my 4wd system??
