Whats the torque spec for the track bar bolt?
Old 01-11-2008, 06:47 PM
itr.#1446's Avatar
I just recently installed a solid steel industry track bar and just recently noticed knocking when turning the wheel back and forth. I had my girl shake the wheel while i was under looking and saw the end of the track bar that connect to the axle moving. I also noticed that it looks like the bolt was moving so maybe its loose(i dont have any tools here now) but i thought i had tightened it pretty good.
Does anyone know what the torque spec is for that bolt? Thats the only thing i hope is wrong there is know way the bushing could be bad already i hope.
Old 01-11-2008, 07:37 PM
Halibrand's Avatar
150 ft/lbs, but most people say tighten it like you aint tightnened nothing before. Kill it. Then tighten the bolt some more.
Old 01-11-2008, 09:03 PM
itr.#1446's Avatar
150 ft lbs holy **** and thats for the bottom to the of the track bar to the axle. What the top torque spec to the frame?
Old 01-11-2008, 09:21 PM
Thundercloud's Avatar
And if that is not enough, replace the trackbar bolts with the redesign ones on an 2008 Ram. They are larger and have improved clamping force.
Old 01-11-2008, 09:27 PM
itr.#1446's Avatar
well i cranked it to 150 but when i shake the wheel back and forth the track bar is still moving and the axle moves side to side also? Each end of the bar move at the frame and axle. I thought the ssi bar was suppose to be solid and not move or is it suppose to move alittle? I have 35 x 12.5 tires and a ssi steering box stabilizer also.
Old 01-11-2008, 11:20 PM
blh1972's Avatar
150 ft/lbs is a good start......I had to tighten mine well beyond that to get the clunking sound to stop.
Old 01-12-2008, 09:32 AM
itr.#1446's Avatar
how far can you torques the bolt before it snaps?
Old 01-12-2008, 11:33 AM
Lsufan78's Avatar
screw the specs...get a cheater pipe and hang on it!!
Old 01-12-2008, 11:41 AM
XLR8R's Avatar
The problem isn't how much torque is on the bolts... you have excessive play in the bar/bushings/brackets.
The trackbar with our zero-deflection bushings won't move at all with just the bolts inserted... no nuts even installed.
Old 01-12-2008, 03:07 PM
itr.#1446's Avatar
i thought the solid steel industry bar was suppose to be good and have good bushings i guess not.
comotionman
08-02-2010 06:42 PM
CTD2001
08-22-2009 10:03 PM
svanni
03-24-2008 03:53 PM
SilverSootXpres
10-07-2007 11:46 PM
Benson
13
04-03-2006 09:46 AM
Quick Reply: Whats the torque spec for the track bar bolt?
