What's so special about the injector pump nut/washer? Replacement?
Old 11-28-2006, 09:42 AM
Dave88LX's Avatar
I saw in a post on here somewhere about a replacement injector pump nut, I can't find the thread now though. It was a deeper nut...anyone know what I'm talking about or where to find it?
Also, my washer is flat, I need a replacement. What kind of metal does it have to be? I called the dealer, they want $21 for the nut, $5 for the washer! If I know what kind of steel/metal I need I can probably get one from the local bolt manufacturing joint here instead, unless there is something special about them? Plus it won't be in until next week.
Thanks...
Old 11-28-2006, 10:22 AM
infidel's Avatar
The washer is slightly concave so that it acts like a lock washer.
Not real sure you'll be able to find one easily elsewhere.
I've aways reused the old nut.
Old 11-28-2006, 10:51 AM
DL1221's Avatar
When I did my timing I changed both my nut and washer, although I could have reused the nut. Got them from Cummins, here are the part numbers:
Nut: Cummins 3920921
Washer: Cummins 3920922
I think the washers are just a few dollars.
Old 11-28-2006, 11:27 AM
Dave88LX's Avatar
I took a quick look at the washer, it looked like an actual lock washer, unless I'm mistaken...?
So it's not just a regular lock-washer then eh...bummer. I have a couple Cummins places around I'll see if they have or can get them.
Thanks for the part #'s!!!
Old 11-28-2006, 11:51 AM
Mcmopar's Avatar
This was originaly posted by "BERNER" on another thread.
Here's a photo of the nut upgrade. It's from Saskatoon Diesel Services Their part # is AT90. Price in 2002 was $14.29.
Old 11-28-2006, 11:53 AM
Mcmopar's Avatar
their web site.
http://www.dieselservices.com/
Old 11-28-2006, 12:50 PM
Dave88LX's Avatar
OK that's what I remember reading, I couldn't find the nut anywhere on the site before though. I guess I should just call up there and ask for it. Nobody's tried since '02?
Old 11-28-2006, 01:01 PM
SHARPMACHINE's Avatar
Do you replace the washer each time?
Old 11-28-2006, 01:54 PM
berner's Avatar
Here's a photo of the nut.
Saskatoon Diesel told me that no washer is req'd with this nut. I think they torqued it to 180 ft-lbs. It was a while ago.
They'll be able to tell you what to torque it to if you call them.
Old 11-28-2006, 02:04 PM
Dave88LX's Avatar
Thanks for the pic...sure doesn't look like a washer would fit with that nut.
I called up a local Cummins dealer, part should be here tomorrow, $11.83 for the nut, $2.90 for the washer. Another dealer was similarly priced. I should probably order that big nut and have it on hand to replace some day though...but for now I just wanna get this hooptie running again.
Old 11-28-2006, 03:32 PM
DL1221's Avatar
I'm sure there are those that don't, and never have any problems, but if you want to minimize the chances of the timing gear slipping on the shaft, its a good idea to replace the washer, and maybe even the nut. Since adjusting the timing is not a job I'm interested in doing more than once, not only did I replace the nut and washer, but I also removed the timing cover so I could take the gear off and hose it down with brake and contact cleaner. Any oil or dirt on the gear/shaft matting surface can cause the gear to slip. I know most people don't do this and never have a problem, but taking the gear cover off also gave me the chance to fix the KDP and change the leaky gaskets.
wisconative
05-13-2013 07:20 AM
Clane
06-02-2012 03:31 PM
dieselman2300
12-19-2007 01:09 PM
woodrat
12-11-2006 02:27 PM
bullfrog
03-12-2005 10:26 AM
Quick Reply: What's so special about the injector pump nut/washer? Replacement?
