Whats nomal psi boost for 04?
Old 06-14-2007, 09:45 PM
PMK
PMK's Avatar
Im getting 20 to 24 psi max boost on my 04 is that low? or about right, i have a quadzilla, and even on the 150 mode, or towing on the 100 mode its the most i get. I have a Scotty air filter, and the 4 inch exhaust with the cool blue tube pre turbo. Im hearing people talk of much more. What is that about? When you guys put after market turbos on that make more boost why? Sorry if its dumb but I havent seen it explained plainly.
PK
Old 06-14-2007, 10:35 PM
Rob C's Avatar
that is normal for a stock turbo on an 03 or 04. To get more you need to use an adjustable boost elbow and some form of a boost fooler so the ecm doesn't through an over boost code. Do some searching on here for boost fooler and boost elbow and you will find all kinds of good threads that will go into great detail.
Old 06-15-2007, 06:27 PM
Rpainter's Avatar
I fyou ever take the stock turbo off you will see the tiny exhaust compressor wheel and know why the factory turbo is so low on boost
Old 06-15-2007, 06:35 PM
RY54's Avatar
I get about 24-25 stock (with intake/exhaust) and with smarty on 130 i get a peak of about 29-30 and it settles at 28.
Old 06-15-2007, 07:02 PM
rip 112's Avatar
I seen 24 stock on mine, 33 on level five and top out at 36 on level 7. So you're at normal psi. Get a boost fooler and adj. elbow or actuator, and you can see over 30psi. 35psi is about the max effeciency range for the turbo, but don't go too far over or the turbo will eventually fail (prematurely).
Old 06-16-2007, 06:47 AM
MikeyB's Avatar
22-24psi stock. 32-33psi with the adjustable boost elbow and SMARTY.
MikeyB
Old 06-16-2007, 06:51 AM
jrsmokestacks's Avatar
40psi with the tst and elbow. No boost fooler,unless the tst does it??
Old 06-16-2007, 09:46 AM
DSmith1178's Avatar
Im showing anywhere from 36-39 psi with my edge juice attitude. Im assuming thats falsely reading high due to some boost fooling. Anybody know what it is really producing with the juice/attitude??
Old 06-16-2007, 10:01 AM
DodgeCTD's Avatar
My boost hit almost 50 psi the other day on the on ramp to get on the interstate with the tst on 9/9 with standard setting and the egts pegged 1500* very quick. I dont have any boost fooler but that seems a little high maybe my boost gauge is reading wrong?
38 Cigarette
16
08-28-2015 11:27 PM
nrussell
07-23-2008 08:58 PM
Tommy93w350
08-07-2007 12:15 PM
Dave88LX
15
09-04-2006 09:30 PM
ckennedy
09-29-2004 05:06 PM
Quick Reply: Whats nomal psi boost for 04?
