Whats that noise?
Old 12-05-2003, 11:44 PM
wagontrain131's Avatar
Whats that noise?
At about 65-70 mhp on the interstate I've got a bad droaning and roaring kind of noise. It has just started in the last couple of months. I know my transmission is going bad, could that be it? Change of subject. Can anyone in the Birmingham Alabama area help me with the kdp, I'm not too sure i want to tackle it alone. Thanks for all the help
Old 12-06-2003, 05:59 AM
bulthisl's Avatar
Re:Whats that noise?
Have you changed your exhaust or is it stock.
Straight pipes and some aftermarket pipes have a drone at about 2200 rpms.
If you have 3:55 gears that is the rpm range you would be at with the speed you described.
: Eddie : 8)
Old 12-06-2003, 10:50 PM
Nope no exhaust mods, you think i might have a hole or a leak?
Old 12-07-2003, 12:05 AM
Rare1's Avatar
Your tires have an aggressive tred. They might have worn unevenly now to the point of making noise at freeway speed.
Old 12-08-2003, 08:29 AM
Paul Winey's Avatar
Wagontrain131:
I've got a similar problem still trying to find. If it's the tires then you should have the same droan when coasting in neutral (you may have to find a hill to keep up speed). If it disappears when coasting then could be tranny or may even be cooling fan clutch going south. Just some thoughts.
Paul
Old 12-08-2003, 11:41 AM
gunracer1's Avatar
the baffles sometimes fall apart in the stock muffler. might want to check that also.
Old 12-08-2003, 05:03 PM
Thanks guys for all the reponses. I'll check into your suggestions.
Old 12-21-2003, 03:31 PM
Lil Red's Avatar
If none of these suggestions work, I had a similar noise in my truck. Thought my rear end was goin bad turned out to be my carrier bearing. Started makin a slight roaring noise then after about year and a half it got worse. Replaced the worn out carrier bearing and no more noise at all.
Necred
04-04-2006 07:26 PM
flashgordon
03-26-2006 01:27 AM
The Domie
01-06-2005 02:23 AM
n2diesels
09-19-2003 08:10 AM
spassey
01-25-2003 12:08 PM
Quick Reply: Whats that noise?
