What's the most weight you ever pulled?
Old 04-30-2008, 10:15 PM
The-Deuce's Avatar
Just wondering what the most weight anybody here has hauled with there 3500 dually?
Old 04-30-2008, 10:51 PM
oldmikegraham's Avatar
Probably won't come close to the weight pulled by a SRW 2500 to Alaska...somebody with the tech expertise please link that thread!
Old 04-30-2008, 10:55 PM
alwaysonDTR
Alwaysworking's Avatar
the most i towed with my srw was 19,500 gvcw so i bet it will be more than that.
Old 04-30-2008, 11:14 PM
slickwillie's Avatar
hit the scales at 42k lbs in a 3/4 ton. only went about 50 miles and it would run 75 down the highway
Old 05-01-2008, 01:29 AM
TexasCTD's Avatar
https://www.dieseltruckresource.com/...ad.php?t=71611 Here is the link about the 43,000lb load to Alaska with a 2500.
Here is another thread about heaviest loads right here.... https://www.dieseltruckresource.com/...d.php?t=158678
Hope that helps.
Old 05-01-2008, 04:42 AM
n2moto's Avatar
Not with a diesel but back in the day I pulled a 18 wheeler with 26 tons of hay plus the weight of the truck and trailer through the mud to the stack yard. Less than a 1/4 mile and didn't go fast. Oh yeah it was with a 1/2 ton Chevy with a 292 6 and a 4 speed. It's nothing compared to what alot of people have done. That was a couple of years before I got my drivers license.
Old 05-01-2008, 07:10 AM
RAMRODD's Avatar
Pulled a 84,000 pound semi about 18 miles into town 2 years ago during harvest truck lost his clutch. It was my grain and not my truck
Other then that I pull up to 42,000 on a regular basis.
Old 05-01-2008, 07:32 AM
c-hawk's Avatar
I like to see pics of these trucks workin... Post them up!
Old 05-01-2008, 08:43 AM
The-Deuce's Avatar
Thanks guys, I will check out those other threads. I just wanted to see what my 2007 6.7,auto,dually was actually capable of pulling.
Old 05-01-2008, 09:02 AM
cincydiesel's Avatar
Hauled a 23,000 lb pinion gear for a large machine at 34,550 gross. Pulled great!! Just took a while gettin her goin.
Old 05-01-2008, 02:04 PM
pappyman's Avatar
I pull 26340 GCVW its 2 bobcats and gear on a 3 axle gooseneck
Old 05-01-2008, 04:36 PM
Busboy's Avatar
Some years ago I was working the afternoon shift at the 747 hangar, it was a hot evening so the doors were open at each end. The sky turned black and we got a call from the tower there was a tornado warning out and large hail. We decided to close the doors but first we would get as many aircraft inside as we could. The hangar would hold 4 narrow body easily so guys took the two tractors that were around and started to drag in a couple of 727's that left one space empty but no tractor.
There was a 4 cylinder Cummins baggage tractor parked so I grabbed that and a couple of guys and raced out to a DC9-32 unladen weight 60,000 lb, gross 109,000 lb. As the small baggage tractor pulled the DC9 it started to rain and when the wet tires got into the hangar the wheels started to spin on the smooth concrete. At this point we can't get the last door closed so guys started to climb onto the tractor to get some traction. The tires spinning slowly dried them and restored traction and we made it into the hangar and closed the doors. I don't think anyone thought that the little Cummins could do it but it sure gave me a new respect for the little diesel engine.
Old 05-01-2008, 06:59 PM
johnh's Avatar
i have pulled around 5 ton of scrap metal to the shredder in slc from where i live.... about 190 miles, dually is no more
czar2906
07-17-2007 10:52 PM
gscmiller
19
10-31-2006 12:44 AM
kev94mx
07-17-2006 08:21 PM
JD 70
17
11-25-2005 09:54 PM
Quick Reply: What's the most weight you ever pulled?
