whats minimum thickness on front brake pads?
Old 05-01-2011, 05:20 PM
plug ugly's Avatar
mine are under 1/4 and squealing at light pedal pressure. Ive got about 60K on them, but live at the bottom of a decent hill, so I would suspect possibly needing replacement. I havent torn them apart to look, just looked at the pads while rotating tires the other day
Old 05-01-2011, 05:37 PM
rockcrawler304's Avatar
I have not torn one of these down yet, but do ours have the little metal "Squealers" on them? That might be what you are hearing. If so, it is time to change.
I would guess 1/4" is probably about the thickness the squealers would start.
Old 05-01-2011, 09:40 PM
plug ugly's Avatar
thats what I was thinking too
Old 05-01-2011, 10:08 PM
LGarrison's Avatar
Dodge will change out life time pads at 3 MM.
Old 05-01-2011, 10:17 PM
Purplezr2's Avatar
3mm=1/8 inch
Old 05-02-2011, 06:45 PM
Grit Dog's Avatar
Shop said my fronts were at 3mm when I had an alignment (75k mi). They were not squealing yet.
Quick easy change out if your rotors aren't warped.
I scuffed the rotors with some 220grit real good like always since they didn't need to be turned and weren't really worn.
Make sure you watch the brake fluid level when squeezing the calipers back in so you don;t overflow the reservior if any fluid has been added.
Old 05-02-2011, 07:29 PM
Dieselbuilder's Avatar
well i put on 120.000 miles and 6 years on my front pads and rotors
Old 05-02-2011, 08:47 PM
plug ugly's Avatar
mileage is relative, it all depends on what you do, where you go, and how you drive.
Diesel_Power_2
12-07-2012 10:02 AM
CZSteve
02-18-2011 01:07 PM
schamran
11-22-2010 07:08 AM
Chip
06-21-2009 03:59 AM
steelblitzkrieg
07-05-2008 02:38 AM
Quick Reply: whats minimum thickness on front brake pads?
