Whats good Dyno #'s for stock injs?
Gonna hit dyno this afternoon to get a baseline with the stock sticks, my F1's will be here sometime today. By the feel of it it may be a hair over 500 but not really sure, I have the Smarty with Beta tune and MP8, also a few other things. My turbo cleans up the fuel by 15psi and makes 45psi with only 30psi drive pressure. Thinkin it may do pretty good if it will lite on the DJ.
I thought the 03 and 04 injectors showed a little less power than the 04.5 and up. I would say 500 is very doable and 600 is possible as Lucas has put dwon 659 with stock pump and inj on an 05.
Only codes I have left to deal with is Cooling fan Circuit, Cooling Fan Speed sensor, Batt Temp sensors, and I get a boost controller 0243 I think it is. Not sure if any or all will make it defuel out of those, no one really seems to know and cant get them to go out yet. I need someone to unplug thier fan clutch and tell me if it defuels the truck.
I know I am getting some fuel cause I can make 45psi of boost with a 76mm charger, thats also with Helix 2 and some head work. Fuel is clean by 15-20psi. It never "noses" over like it goes into limp mode, pulls hard all the way to rev or speed limiter.
I think the biggest reason my truck has 650 is the bully dog version I run.
448/700
Bout what I thought it felt like, mid 400's when it lites, low tqu cause of the big turbo. I think I still have something pissin the ECM off and its holding it back. Anyone know what thier truck does if the fan clutch is unplugged? I am not running a stock fan so I get the codes for it and that may be causing some issues.
Yes, Mp8 and Beta Smarty.
Here is a list of codes I got to deal with,
0602 Checksum Error
0462 Fuel Level Sending Unit
0483 Fan Speed
0480 Cooling Fan Control Circuit
0243 Wastegate Pressure Control
0628 Low Voltage At the Lift Pump
Anyone got some suggestions here?
0602 Checksum Error
0483 Fan Speed
