went from an sps62 to an HX35-12w
Old 05-04-2007, 07:24 PM
Forrest Nearing's Avatar
also went to 215 injectors from DDP4 injectors, but I've run the sps62 with stock injectors so I can make a good comparison here
wow... just wow...
anyone on the fence considering one just buy one, obviously the stocker lights sooner, but really? not that much sooner!!
and I don't know if anyone's ever run a drive pressure gauge w/ a stock turbo, but it's kinda spooky... I've got to play w/ the wastegate and get it dialed in, but as RPM climb, the drive pressure goes WAY up... if you've got an HX35 set at 35-36psi and you're revving to 4000rpm, I'd say you're way over 50psi driver pressure.
anyhow, just couldn't believe how "laggy" the stocker really is in the grand scheme of things.
Old 05-04-2007, 07:43 PM
JaMan 02''s Avatar
Me either I just put a HY-9 on while my SS62 is in the shop for repair of some wheel damage and th HY spools alittle earlier but also slower...
It Sucks...wg at 23psi
Jared
VikingDiesel
08-12-2007 10:10 PM
cjones42
05-10-2006 08:49 AM
Reaper
04-07-2006 02:40 AM
metal_miner
03-18-2006 04:36 PM
drew03
76
02-06-2006 07:57 AM
Quick Reply: went from an sps62 to an HX35-12w
