Weird headlight issue
Old 01-09-2009, 11:25 AM
dubmatic's Avatar
Have any of you guys had it where one headlight came on by itself while the vehicle was off?
I came out this morning truck was off and the passanger headlight only was on. I checked and the lights were turned off. I tried turning them on and off again yet the passanger side didn't turn off.
Currently Im running hid's with relays for the low beams and standard bulbs for the highbeams.
Old 01-09-2009, 04:53 PM
Bluedually4x4's Avatar
I would guess something in the wiring on the passenger side shorted out and completed the circuit enough to put juice to the bulb.
Old 01-09-2009, 06:43 PM
mopar-or-no-car's Avatar
The headlights are negative switched so I'm guessing that there is constant power supplied to the bulb but they dont go on untill you turn the switch on which grounds the bulb and completes the circuit. So I think maybe a wire has rubbed through or something and caused it to ground. I could be wrong but thats my guess.
Old 01-09-2009, 08:20 PM
infidel's Avatar
My experence with electrical problems is that the majority are owner induced.
I would check any aftermarket wiring you did or had done.
Old 01-09-2009, 09:50 PM
bob4x4's Avatar
I second that
Old 01-10-2009, 12:26 AM
wyododge's Avatar
I Third...
Stuck relay
Old 01-10-2009, 11:52 PM
rage_blue's Avatar
They day time running lights used to cuase both front headlights to stay on. The way to diaganose is to just unplug the module and see if the lights go off. lights go off you need that module. The module is on the left fender is rectangular and i think a dull silver color.
Old 01-13-2009, 05:10 PM
dubmatic's Avatar
Truck doesn't have day time running lights trucks from the states. Ya it was a faulty relay
Old 01-13-2009, 05:48 PM
smokeyram's Avatar
i came home from a movie with the wife one sunday to see my truck in the drive, all the lights on. after some messing, finally found the contacts in the trailer brake harness were contacting one another, re feeding the electrical system from the back.
Old 01-13-2009, 10:25 PM
Dinner's Avatar
Electrical can do some pretty funky stuff
mtdoragary
11-07-2013 08:31 AM
jweese
01-15-2011 06:42 PM
Common
04-09-2008 10:25 PM
Rocky5.9
03-06-2007 12:14 PM
jlipskoc
10-24-2005 01:16 PM
Quick Reply: Weird headlight issue
