weight of a gen 2 Cummins
Old 05-26-2003, 11:27 AM
nevrenufhp's Avatar
My nephew has the bombing bug and is thinking of a cummins swap to his Ferd pickup. Is there anyone or a website that has measurements like height, width & length at various locations. And what does a Cummins weigh, I heard it's right at 1000 pounds...that would be 350 more than his old FE . I told him if he got one I'd find a way to put it in and work. My fear is traction(lack of) and the starter being so low mounted. Of course he'd be getting GSK, and injectors and a couple other bombs ;D. My mental gears are turning and the cost of the little things is going up fast!
Old 05-26-2003, 11:29 AM
nevrenufhp's Avatar
Re:weight of a gen 2 Cummins
Question # 2: Does a 1st gen auto work well with a gen 2? Like is it any different using the 518 vs a 47rh..it doesnt really need lockup and the extra wiring of such.
Old 05-26-2003, 03:10 PM
SjLingenfelter's Avatar
To help you out somewhat a cummins motor weighs in a 1400lbs. Dont know the height width and other but I know it ways 1400 and it can be put in a stock ford frame with little bit of moving around.<br>SD03
Old 05-26-2003, 03:36 PM
nevrenufhp's Avatar
I went out and measured mine, but didn't know if there was any real figures. I rounded to the next higher inch for error factor. It would be really neat to see, it's a '72 F100 shortbed. I told him about brake upgrades, at least a Dana 70 or GM 14 bolt, Linkages, and the can of worms to get it done.I still don't think it can be done for $3k(excluding engine/trans/ &amp; rearend). He wants the least expected way to blow someone away, well that and he really likes black smoke! :
Old 05-26-2003, 04:03 PM
Haulin_in_Dixie's Avatar
[quote author=SuperiorDiesel03 link=board=8;threadid=15147;start=0#142274 date=1053979843]<br>To help you out somewhat a cummins motor weighs in a 1400lbs. Dont know the height width and other but I know it ways 1400 and it can be put in a stock ford frame with little bit of moving around.<br>SD03<br>[/quote]<br><br>The cummins site says that the isb weights 1000 and the isc is 1500.
Old 05-26-2003, 04:13 PM
phox_mulder's Avatar
[quote author=Haulin in Dixie link=board=8;threadid=15147;start=0#142283 date=1053983037]<br>[quote author=SuperiorDiesel03 link=board=8;threadid=15147;start=0#142274 date=1053979843]<br>To help you out somewhat a cummins motor weighs in a 1400lbs. Dont know the height width and other but I know it ways 1400 and it can be put in a stock ford frame with little bit of moving around.<br>SD03<br>[/quote]<br><br>The cummins site says that the isb weights 1000 and the isc is 1500.<br>[/quote]<br><br>Figure in accessories, fill it with oil and coolant, and you will be close to the 1400#'s.<br><br><br>phox
Old 05-27-2003, 07:14 PM
SD03
[/quote]
[/quote]
The HO's weigh in about 1370 I think thats what I heard.
SD03
Old 05-27-2003, 07:28 PM
Stamey's Avatar
All you need to know:<br>http://www.fordcummins.com<br><br>Chris
Old 05-27-2003, 07:44 PM
Went and looked, the isb, dry, with accessories weighs 964 pounds. Info from cummins commercial engine section.
Old 05-27-2003, 08:31 PM
PumpDaddy's Avatar
Even if you upgrade springs and everything to hold it up, will the F100 frame even handle the torque. I used to have a 79 F100, 302, 3spd, it wouldn't pull the hat off your head even in a strong wind. It would be ugly to see him punch it and the Ford be twisted like a worm in the sunshine
Old 05-27-2003, 09:57 PM
nevrenufhp's Avatar
That's what I've been thinking. Besides the fact that anyone that has a Cummins laying around either has plans for it or wants too much$$$$ for it :. Maybe he'll like a 514 big block stroker instead. I think the cost would kill the Idea, since he has $3k to do it all :-X. A buddy of mine has a couple brand new ISB's &amp; they're a pretty penny!!!!
John Marshe
08-14-2020 09:00 PM
Purplezr2
07-25-2011 04:31 PM
PourinDiesel
Competition / Pulls / OffRoad
13
04-03-2006 09:20 PM
Ripper406
01-29-2006 04:42 PM
fjbiker86
12-13-2005 06:42 PM
Quick Reply: weight of a gen 2 Cummins
