What wears out in the APPS?
Old 09-05-2011, 07:35 PM
Tree DR's Avatar
Just wondered what happend inside it.
Old 09-05-2011, 07:36 PM
dkenny's Avatar
most likely..
contact issues..
or electrical noise kills the transistors inside
Old 09-05-2011, 09:04 PM
Tree DR's Avatar
If it killed the transistors why would the dead peddle be intermitent?
Old 09-06-2011, 12:52 AM
pind's Avatar
if you break down the apps, you'll see two filaments in there. The apps is basically a potentiometer. ( variable resistor ) what happens is the ribbons get "flat" spots in them, which occcur at the most frequently used settings.
For me, its at cruising speed on the highway. After a couple years, on comes the dead zone. You can do a hard reset and buy some time, but you'll end up changing it anyway.
Old 09-06-2011, 07:04 AM
Tree DR's Avatar
Mine first did it about 8mo ago at 55-60mph 3 times one day. Never reset it. Now it did it at 40-50mph 4 times. Haven't driven it since so don't know if its going to do it again. If it was a flat spot why did it not continue to do it? And why is it doing it at a differen't speed now?
Makes me think its a contact issue. Or an electrical problem somewhere else messing with it. My exhaust brake quit working about 5min before the APPS started acting up. Exhaust brake started working again after I shut truck off, and APPS didn't do it again after shut off either. Makes me think its a computer problem cause by a short somewhere.
Old 09-07-2011, 01:00 AM
pind's Avatar
it is an electrical problem, caused by a bad contact within the apps. Hence the flat spots that I described. Many times, if you sit with the truck in neutral, running, and carefully play with the throttle pedal, you can make it throw a 0121 or 0122 code. You'll know it when the check engine light comes on.
Try it out for fun
Old 09-07-2011, 11:35 AM
Tree DR's Avatar
I calibrated the APPS. The white sticker on APPS said .551 and when I check it at the PCM it was .448 so while I had the volt meter hooked at the PCM I adjusted the APPS to .551. As I tightened the APPS it change to .549. Figured it was close enough. I did recheck it at the APPS and it read .552. So far in 35mi it hasn't dead pedled again. Also while I had the APPS off the truck I sprayed it down with some electrical connector cleaner. Not much of an opening to spray it in but anyway.
Old 09-13-2011, 10:08 PM
Tree DR's Avatar
Update, 600+ mi and not problems. Done 100+ of that in town with and without 4k trailer. Ive got the new APPS incase I need it.
Old 09-16-2011, 08:49 AM
gsbrockman's Avatar
I had some "dead pedal issues" on my 1999 RAM 2500 Quad Cab.
I tried this :
https://www.dieseltruckresource.com/...n&onlynewfaq=1
.....and all seems to be well. I guess I'll for sure know on my next hauling job. It sure did seem like a heck of an improvement on my short 5 mile test drive just a few minutes ago.
Old 09-16-2011, 11:00 AM
TOM R's Avatar
when I had mine apart i noticed that the hole in the bracket where the throttle shaft goes through to the sensor was egged out quite a bit
Old 09-17-2011, 08:08 AM
Tree DR's Avatar
I did reset the APPS after I calibrated it. I think my idle is a little higher. I haven't had an opertunity to check fuel mileage yet. I had adjusted the valves about a week before and got 20.4 with normal gear and 20.1mpg with 17ft canoe on top, was 19.6-8 at 75mph might get a chance this weekend to check mpg. After I calibrated and reset APPS power is better at 14-1700rpms in particular.
Old 09-25-2011, 08:57 PM
Tree DR's Avatar
mpg has improved. Mixed driveing 800+mi, (200mi city 100 with trailer, 600hwy, 200loaded heavy with wood, 75mph) 22mpg. Still have new APPS in box. This is my 10th dodge diesel and I never got above 18mpg on any of them so this high mpg stuff used to be unbelieveable to me but this is my first 3/4ton.
clutches4life
09-01-2009 07:35 AM
mx261
12-13-2005 02:06 PM
HorseHauler
11-16-2005 09:30 PM
hotdram
09-25-2005 11:44 AM
Quick Reply: What wears out in the APPS?
